280zx na->turbo
Old Mar 1, 2004 | 07:33 PM
lifegrddude's Avatar
Externally Wastegated
You will need the turbo, exhaust manifold, oil return line, oil supply line, injectors, fuel pump, and some other stuff that I'm sure someone else will know. You can run a turbo on your n/a but you won't be able to crank the boost as high. 5 psi will be fine, heck even Honda EX Civics can take 6 psi of boost without problems, just be sure your motor is healthy before you slap the snail on though.
John 82ZXT
Old Mar 1, 2004 | 09:58 PM
Fredrik's Avatar
At 5psi you dont need new injectors or fuel pump. If you want to run a little higer boost you can use a progressive FPR and the injectors will be good for a bit more than 200 hp.
Old Mar 2, 2004 | 11:14 AM
Really? You don't need to upgrade the n/a injectors? Wow, I figured they'd be maxed out or running near peak duty cycle. Well, I guess that's another item where you can save money then!
John 82ZXT
Old Mar 3, 2004 | 01:27 AM
Fredrik's Avatar
Running at 3.0 bar fuel pressure the stock 217cc injectors should be good for at least 200 crank hp, probably closer to 220chp. If you use a progressive FPR and increase the fuel pressure during boost they can deliver even more fuel when needed. I cant remember how much the fuel pump is good is good for, but it will be good for at least 250chp. Let´s say that you will need 0,5l/hp/hour. The pump flows around 125l/hour (please correct me if i´m wrong) 05l*250hp= 125 l/hour
If you just want to enrich the mixture a liitle you can do it on the AFM. What you want to do it is to take off the black cover, and inside there are two screws, you want to loosen the one that holds a geared wheel on a spring. You want to loosen the spring to enrichen. Remember the initial position and do not let the spring unwind.
Edit: I just found out that it´s called rising rate FPR, sorry
koprutzxt
Aug 2, 2012 11:55 AM
DUBAUDIO
Feb 1, 2012 07:47 PM
benny127
Sep 13, 2010 12:13 PM
280ZX_AV8R
Sep 30, 2005 02:37 PM
JustinToxicated
Dec 16, 2003 07:36 AM
