240sx
Old Jan 15, 2009 | 07:42 PM
FubarI33t's Avatar
240sx
" Its common practice to swap a 240sx tranny to a S30 or S130" quote from Cville300zx from Memphis Racing Scene. WTF we can do that?
Old Jan 15, 2009 | 10:15 PM
lifegrddude's Avatar
Externally Wastegated
You can swap in the transmission, but it's not a bolt in swap. You have to do a little machining. The transmission is a mild upgrade, but if you're going to go through the hassle you're better off doing the custom work to a Z32 transmission and buying the adapter plate to match up to the L-motor.
Old Jan 15, 2009 | 10:26 PM
its good if you want 400 hp though. its drilling out the number one shift hole and counter boaring one of the main bearing slots of i also heard you can just swap the main bearing then you simply bolt the front half/bell housing of the S30 tranny onto the SX tranny. as for driveshaft i think its custom made. that or the stock one is just shortened 3 inches or something.
Old Jan 16, 2009 | 05:53 AM
FubarI33t's Avatar
eh. i guess if i could get it in 6 speed then it might be worth it. other wise. i think i'll stick to my t5 search
Old Jan 16, 2009 | 08:09 AM
the sx tranny is stronger than the t5 and great for a mild slightly powerful build. but if you want REAL power than a Z32 tranny is the only way
Ryan280
Mar 30, 2007 12:55 PM
FubarI33t
Mar 11, 2007 12:27 AM
FubarI33t
Jun 6, 2006 11:44 AM
benderzjamez
Other Cars
Jan 10, 2006 06:38 AM
datto
Aug 5, 2001 01:37 PM
