Power steering leaking bad?????????
Old Oct 31, 2004 | 07:17 AM
Cw2435's Avatar
Question Power steering leaking bad?????????
My power steering has been leaking since i bought my z 4 years ago. I haven't had the money to fix it but it just recently started getting worse, so I jacked it up to see where it was leaking an it is in the steering box where the lower joint of the steering arm screws into it. I was wondering if you can just replace the seals yourself or if you just have to buy a new part?
Old Oct 31, 2004 | 09:11 PM
What year of car do you have? 1981?
Old Nov 1, 2004 | 10:28 AM
Cw2435's Avatar
1982
its an 1982
Old Nov 1, 2004 | 12:43 PM
You have the rack in pinion power assist steering. I have heard that you can replace the seals in the rack. (or swap in a used rack) I have never done this.
Are you sure its not leaking from the pressure hose connected near the point that you described? That is the common part that leaks.
Old Nov 2, 2004 | 09:17 AM
sanchiz's Avatar
280zx power steering leaking
[FONT=Century Gothic]I just overhauled my 280zx power sterring pump and rack, if you are going to do it yourself is a time consuming procedure. I had to remove the crossmember and lift the motor with a jack. At the same time I changed the "Tension rod bushing, Rack and Pinnion rubber base, tie rod ends, boots, rack and pinnion high an low pressure hoses.
Saludos Gustavo
Old Nov 3, 2004 | 06:24 AM
johntlr1000's Avatar
rack n pinion
I have an 82 and have the same problem I am gonna replace the whole rack however to do it you either have to take half the under carage apart or pull the motor up a little. As far as the seals go I could not find a local place that carried a rebuild kit. A new rack runs about 175$ good luck
Old Nov 4, 2004 | 08:06 AM
Cw2435's Avatar
Thanks for the information and help i'm problay going to have to take it somewhere to get it done because i don't have the time that is needed, and its my every day driving car, so thanks for everything
Zachrates
Jan 27, 2007 04:35 PM
graverhead
Dec 14, 2005 12:39 AM
260DET
Aug 31, 2005 10:03 PM
tsefreeflow
Oct 4, 2004 08:01 AM
shall345
Jan 4, 2004 03:10 PM
