manual steering???
Old 08-14-2003, 11:04 AM
1979 280zx came with manual steering. Power steering was an option.
1982-83 had rack and pinion power assist steering. If your power steering goes out, you can still drive.
Bleach is offline
Old 08-22-2003, 10:23 AM
zpeedracer25's Avatar
My first ZX had manual steering. It was a base model 1980. I believe that you'll also need to grab the front crossmember to do the swap as yours isn't set up for rack and pinion. I've looked at doing this on my daily driver for better steering response and weight savings. I'm not sure if the steering column is the same on these either...hmmmmm.
zpeedracer25 is offline
Old 04-30-2004, 05:54 PM
duckyz's Avatar
Well, it all depends on how you like the feel. My power steering pump went out a long time ago...and it really sucked in in-town traffic, and backing out of the driveway. The response was ok at freeway speeds, but I really prefer the power steering.
duckyz is offline
Old 05-03-2004, 09:35 AM
Also keep in mind that a power steering or power assist setup is going to be geared higher. Fewer turns of the wheel from lock to lock. A manual steering setup will be geared lower so it takes more turns of the steering wheel to turn the wheels a certain amount. It will be a little easier to drive a manual steering setup than a power steering setup with a broken pump. i also have driven my power assist setup with out the pump. It was livable. I gained 1mpg during the time I had the belt off the pump.
A full power steering setup would be much worse. 1981 had full power steering. Also, the 1982-83 power assist still lets you feel the road while driving. I like how that setup is.
Bleach is offline
Dr_Nic_T61
13
10-04-2016 12:05 AM
ITSZX
03-28-2014 07:19 AM
graverhead
12-14-2005 12:39 AM
Moffer
09-13-2004 11:44 AM
mescalinedreamz
04-01-2004 10:26 AM
Quick Reply: manual steering???
