2+2 Shocks/Springs on 2 seater??
Old Jul 9, 2006 | 04:40 PM
rxKaffee's Avatar
Would it be a direct drop in for increased stiffness to put a set of OEM-type 2+2 springs and shocks on?
I'm looking for an ultra cheap shock fix to the saggy old busted crap on the car now. Will be re-doing the suspension totally soon. Just looking for something somewhat capable to hold me over until we findout if frank280zx's Z31 setup works out well
And would it be reasonable to take a coil or two off of the fresh oem springs to lower the car a little?
Old Jul 9, 2006 | 04:56 PM
nismo619's Avatar
thats a good question i was planing on puting some spare 2 seater shocks and springs on my 2+2... i do belive they interchange.. pretty much the same stiffness etc...
Old Jul 9, 2006 | 06:48 PM
2seater & 2+2 fronts are the same. 2+2 rears are a lil stiffer. If you want a cheap setup to stop the rear squat... get some 79 - 83 Mercedes 300D front springs & chop them down to the right height. I found out they fit great & are stiff as hell:
http://www.cardomain.com/ride/403158/3 (the silver one on the strut is the 300D spring)
Old Jul 9, 2006 | 07:40 PM
thxone's Avatar
Hey, I have a question. How long does it take on average for new shock/struts to break in on the rears to where they settle to their final hight?
Old Jul 9, 2006 | 08:29 PM
they settle in the first drive, aboot 5 seconds after you start rolling
Old Jul 10, 2006 | 02:26 PM
DatZun Driver's Avatar
You can use 350Z springs for the back you got to chop them down.
Old Jul 10, 2006 | 02:32 PM
Same diameter eh? Cool... except they'll prolly cost as much as a set of performance 280zx Eibach springs....
Old Jul 10, 2006 | 03:04 PM
I've got aboot 2 mercedes springs uncut and for sale! PM me if interested. (they are the same ones pictured)
Old Jul 10, 2006 | 03:35 PM
RodMoyes's Avatar
Doesn't post much...
Dude, Just because you live near Canada doesn't mean you have to talk like a hosehead eh'
Rod.
Old Jul 10, 2006 | 06:44 PM
rxKaffee's Avatar
Are the struts from 2+2 and 2 seater identical?
Old Jul 10, 2006 | 07:04 PM
[QUOTE=NismoPick]Same diameter eh? Cool... except they'll prolly cost as much as a set of performance 280zx Eibach springs....[/QUOTE
They only work on the back. I got mine for free from someone lowering their Z. They are stiff and I get no squat at all.
Old Jul 10, 2006 | 07:43 PM
nismo619's Avatar
lol u should see my 2+2 squat lol almost all the way down to the muffler.. lol no joke.. thats why i was gonna swap out my 2 seater set up
Old Jul 10, 2006 | 09:07 PM
Rod.
dude, I'm going to Canada in four days! I gotta practise up on my Canadian speech, eh
Old Aug 6, 2006 | 08:28 PM
HybridS130's Avatar
Okay so just to clarify, the mercedes springs will work for all four corners, you just cut them down to the proper height and you use the oem replacement shocks for the 280zx? Sweetness, I went into Oreilly auto today and they don't even carry suspension parts for the S130, I figured I might as well replace the springs too since it's so old.
Hooray New Suspension!
Edit: I just reread the thread and I realized what was said about using the front springs for the rear, does this mean that only the rear will accept the mercedes springs?
Old Aug 6, 2006 | 09:28 PM
Yep... Front 300D springs fit the rear 280zx's. I never researched thru the junk yard to find something more stiff to fit the front.
Old Aug 7, 2006 | 07:59 AM
lww's Avatar
lww
Head Muckraker
And the Mercedes springs are stiff as hell. They have almost no give on the relatively light weight rear of a 280ZX compared to the 300D's 6 cylinder diesel motor they're designed to support.
I think the spring rate on the 300D's is in the 300lb range. I believe ours are about 180lb for the coupe and 200lb for the 2+2, so you're talking about a 50% increase in stiffness over a stock 2+2.
I think the guys that have used this can testify to their stiffness.
I would only use it as a temporary fix. Normally, you want some give in your springs for uneven pavement and road holding on city streets/highways.
If you want to drift, they're the perfect add-on!
Old Aug 7, 2006 | 08:13 PM
HybridS130's Avatar
Oh yeah I didn't even think about the stifness making the car unstable, thanks for bringing that up lww. I think I'd be better off going all out and getting an actual set of springs from MSA or something. Im trying to put together a decent yet inexpensive suspension with new springs, struts, bushings, and some strut bars
Old Aug 8, 2006 | 01:03 PM
ST springs are pretty stiff. I'm happy with the set I bought.
although, the front dropped more than the rear.
Granpa's z
Sep 14, 2013 01:55 PM
LikeZcars
Aug 11, 2011 11:33 AM
Flacster
Apr 3, 2011 10:54 AM
jrs260z
Apr 26, 2008 04:52 AM
toecutter
Jul 21, 2002 12:44 PM
