What Cleans Your Glass Good?
Old Mar 7, 2007 | 05:56 PM
3XAZOWNER's Avatar
My windshield and windows have a hazy and a "hard water spotted look" on them after they are cleaned with Windex. Is there something like vinegar etc. that can make glass look clear? Or is it just old hazy glass that I will have to live with? Thanks.
Old Mar 7, 2007 | 06:04 PM
RodMoyes's Avatar
Doesn't post much...
C.L.R. is what you need...
Old Mar 7, 2007 | 06:11 PM
z-hag's Avatar
Queen of Yachts
vinegar does the best job--i use it exclusively in my washer system and never have problems unless i run out for more than a few days........using straight vinegar in the winter in snow country keeps the salt buildup nonexistent.......ya dont need stronger stuff to erode the system--vinegar does it gently and thoroughly,,,,,,,,,,,,,,,smells like salad when ya use it, too--kinda different.......just plain white distilled vinegar.......cheep, too............ ......i use it on my boat, too.....
.........BTW------rods stuff works too----it is just stronger...........
Old Mar 7, 2007 | 06:20 PM
RodMoyes's Avatar
Yeah, OK... So... Like I was saying earlier...
FOR HARD WATER SPOTS YOU NEED C. L .R.
Old Mar 7, 2007 | 07:42 PM
thxone's Avatar
Windex is a joke...what you need is sulfuric acid and bleach...mix well with ammonia and easy off oven cleaner with a dash of BAM!! Breath deeply...if you wake up your head will be fuzzy and you won't think about your windshield so much
The C.L.R. Will work as well as the Vinegar, just scrub with a green Scotch Brite pad in small circles, rinse off with water and you should be good to use the windex after to get rid of any streaking. I would get some good old RainX and do the outside when it is clean. The inside may be cleaned with straight windex and newspaper...just push fairly hard with the news paper and when you are done it should look transparent....the glass that is.
Old Mar 7, 2007 | 08:22 PM
z-hag's Avatar
Queen of Yachts
and when the old stuff goes away, put vinegar in the washer bucket.......keeps the crud away........
Old Mar 7, 2007 | 10:45 PM
DONT USE RAIN X OR SIMMILAR PRODUCTS. they really suck, drive at night and turn on your wipers, they leave a momentary streak behind the wiper that blinds you when lights are coming the opposite way. it also leaves a weird film that takes ages to go away. not to mention it does fling the misty kinda rain off the windscreen forcing you to use your wipers causing the above problem. vicious cycle. i hate all that crap. vinegar works great. for the inside get the spray foam for automobiles.
Old Mar 8, 2007 | 12:01 PM
thxone's Avatar
You are making that up shady ....actually, I have never had a problem with rainX...it's all in how it is applied....use a few drops of water when removing the haze after it is applied and that's it...always works good for me as long as the glass is perfectly clean before it is applied.
Old Mar 8, 2007 | 12:20 PM
Indeed. I'm a big fan of RainX. The only problem I've ever had is staring at the drops flying up my windshield at 70mph... EYES ON THE ROAD!!!
Old Mar 8, 2007 | 12:36 PM
OH, youre supposed to put rainX on the outside of your windshield! Now I see why it wasn't working
Old Mar 8, 2007 | 12:45 PM
skittle's Avatar
Taste My Rainbow
Purple Power!!!!
Old Mar 8, 2007 | 03:47 PM
SpeciallySpiked's Avatar
I'm a Registered User!
I <3 RainX as well and never have had any problems
... you did follow the instructions right?
Old Mar 8, 2007 | 08:19 PM
entropy31's Avatar
The Cake Is A Lie!
one more on the side of RainX. stuff works great. lights at night do flare a bit for a day or two, but nothing dangerous.
Old Mar 9, 2007 | 02:22 AM
Heat Rave R's Avatar
Anyone got any good chemical tricks to stop condensation from fogging up the inside of the windshield?
Old Mar 9, 2007 | 06:20 AM
entropy31's Avatar
The Cake Is A Lie!
condensation means moisture in the car. get a dessicant pack at a boating supply store and leave it in the car.
Old Mar 9, 2007 | 10:11 AM
RodMoyes's Avatar
That could very possibly be the smartest damn post EVER!!!! You are a freaking GENIUS!!!!
I'm going to go get one today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Rod.
Old Mar 10, 2007 | 01:02 AM
Would that act quickly/adequately enough to eliminate the condensation when you get in the car on a cold night and try and turn on the heat?
Old Mar 10, 2007 | 10:55 AM
entropy31's Avatar
The Cake Is A Lie!
they arent instant, they need some time to work. you know those little DO NOT EAT packets you find packed with things sometimes? same idea. it's a chemical compound that absorbs moisture. condensation happens on the inside of your windows because there is moisture in your car. these things just soak the moisture right out of the air. they also help if you have a dank mildewy smell in the car, because moisture is causing that.
Old Mar 13, 2007 | 07:46 PM
lww's Avatar
lww
Head Muckraker
I get dozens of them in the boxes our servers are shipped in. I usually grab a dozen or so every couple of months to replace the old ones in my gun safes.
I had a seal leak in my 240Z when I first got it and I used a boat load of them in there after I found and sealed the leak.
Old Mar 14, 2007 | 08:33 AM
lifegrddude's Avatar
Externally Wastegated
Back in the day I used to use shaving cream on the visor of my hockey helmet and it worked to keep out condensation on the inside of the glass. I think it should do the same for a car.
Old Mar 14, 2007 | 04:52 PM
Oh yeah, I almost forgot that spitting into your goggles when diving helps keep them from fogging. Haha, now I only need to spit all over the inside of my windshield (I better start drinking some water!) =P
Old Mar 14, 2007 | 07:34 PM
3XAZOWNER's Avatar
Yeah, leave your girlfriend at home when you go for a ride, or at least crack the windows when things get steamy.
Hey, maybe Rainex on the inside would solve that!!!
Old Mar 14, 2007 | 07:37 PM
entropy31's Avatar
The Cake Is A Lie!
again, dessicant packs. seriously. just try it.
Old Mar 15, 2007 | 04:13 AM
BigEkak1941's Avatar
I learned as a kid to break up a cigerate and rub it in your face mask with a little water. That would keep the mask from foging up when swimming. It might work on the same principle, but too much trouble for a car windshield.
Old Apr 11, 2007 | 12:18 PM
Thomo's Avatar
Polish the inside of your windshield and windows with toothpaste....really...
A trick I learned scuba diving, it fills in all the peaks and valleys in the glass which collect condensation. It'll just be a pain in the @$$ but you will be able to see and it will leave your car smelling minty fresh!!
305zx
Sep 4, 2011 12:16 PM
colin_barnes
Jan 6, 2006 09:56 AM
psycho78
Sep 14, 2005 08:39 PM
atomicon
Jul 9, 2005 06:28 PM
reefatx
Sep 30, 2004 08:22 PM
