Voice Warning Betty iPOD MOD
280ZX Voice Warning - Bitching Betty MOD - YouTube
Here is a video of the MOD I did to make the BETTY vocal again when using an aftermarket radio.
Enjoy...
Enjoy...
1983 GL Power antenna, radio rewire, betty speaker MOD
This is a new video i did where I am showing some mods to the RADIO, Antenna, and Betty Speaker. I took all the knowledge from all over this forum and made a video to make it easy.
I hope you enjoy it!
im curious as to how you got your power antenna to work with an aftermarket radio, right now, I have a constant 12V to the antenna, so I would also need a switched 12V from the ignition or the radio to the antenna? is this correct?
all aftermarket radios have a wire to that purpose (12v switched), blue with white stripe or simple blue.
ok that's what I thought, but im currently running an amp in my car and that's what that is used for, so, my next question, can I splice that wire to use for both the amp and the antenna? or should I run a separate wire for the antenna?
yes you can put the both things (amp / antenna) in that wire.
