Steering wheel hub
Old Mar 31, 2005 | 11:45 AM
DarrellBuddy321's Avatar
Steering wheel hub
I want to use a nardi steering wheel but i dont know what steering wheel hub i can use? Can some help out? What have you guys useD?
Old Mar 31, 2005 | 12:36 PM
I used the Datsun 280Z/ZX adaptor for my steering wheel. I think all Pre 1984 Nissans use the same one.
Old Apr 10, 2005 | 12:57 AM
ZedZilla's Avatar
Smile
It all depends on what bolt pattern your steering wheel has. I would suggest you do a web search for Nardi hubs if not already done.
Grant makes a black finish "Euro" hub or a "Billet" hub for the Datsun 280 ZX that you can marry up to a 5 bolt Grant steering wheel or, as in my case, a Momo adaptor to bolt on a six bolt Momo wheel. In the Grant catalog its called the "momo wheel to grant hub" adaptor. I have one set up on order now for my wheel. if the Nardi has only 5 bolts then even a regular Grant hub may just work as long as the holes line up.
Or you could also just custom jobie it. Use a grant hub for the datson, have a machine shop do up an adaptor plate for you with matching holes to install your steering wheel. So basically it would be your wheel bolted to the custom adaptor plate (with the dual bolt pattern for the steering wheel and the Grant hub) which is bolted on to your Grant hub.
have fun
Donn144
Feb 12, 2014 08:35 PM
joi_b
Jan 30, 2013 11:46 AM
workingprogress
May 24, 2011 06:13 PM
kevtt
Jun 27, 2005 04:44 PM
Skully
May 15, 2003 03:15 PM
