280ZX-R Hatch Strut Replacement
Old Apr 3, 2014 | 04:17 AM
stiletto660's Avatar
I wanted to pass on some information about heavy duty struts for any ZXR owners looking to replace your weak or worn out hatch struts. I have tried a few different standard struts with less than desirable results due to the weight of the hatch with the whale tail most struts are just not the right capacity rating. I have found that the capacity needs to be a minimum of 70lbs. The original struts (Nissan #99996-R8004) I believe have an 80lb. rating. I have attached a PDF with the specs. I found that work well.
Enjoy the ride!
Phil
Old Apr 3, 2014 | 10:56 AM
w00t!
The Z32 hatch struts are also an easy upgrade option: https://www.zdriver.com/forums/280zx...s-280zx-31527/
Old Apr 3, 2014 | 12:19 PM
borini63's Avatar
w00t!
Make sure you get the 2+2 z32 struts,the coupe Z32 is shorter.I have a set in my 280ZX right now and they work perfect with the spoiler and heavy rear hatch louvers.
Old Apr 5, 2014 | 07:05 AM
yup i have a low pro whale tail on mine and went the z32 route.
Old Sep 27, 2014 | 12:35 AM
farqyj's Avatar
Old thread bump, but I used hatch struts from a old Nissan minivan hatch. Ended up about an inch shorter, but will lift the hatch with the touch of a pinky finger!
Old Oct 9, 2014 | 12:26 AM
borini63's Avatar
In the warm days I don't even have to touch the hatch,It will pop up by it self.....I always empress the Z croud about the powered hatch.Lol.
awilkie
18
Nov 10, 2010 02:26 PM
BigEkak1941
Feb 13, 2005 04:46 PM
newb81280zx
Dec 19, 2004 02:49 PM
Creator
Nov 10, 2002 10:18 PM
AlansZ
Dec 11, 2001 07:13 PM
