280ZX-R Hatch Strut Replacement
1 Attachment(s)
I wanted to pass on some information about heavy duty struts for any ZXR owners looking to replace your weak or worn out hatch struts. I have tried a few different standard struts with less than desirable results due to the weight of the hatch with the whale tail most struts are just not the right capacity rating. I have found that the capacity needs to be a minimum of 70lbs. The original struts (Nissan #99996-R8004) I believe have an 80lb. rating. I have attached a PDF with the specs. I found that work well.
Enjoy the ride! Phil |
w00t!
The Z32 hatch struts are also an easy upgrade option: https://www.zdriver.com/forums/280zx...s-280zx-31527/ |
(Post 332877)
w00t!
yup i have a low pro whale tail on mine and went the z32 route.
Old thread bump, but I used hatch struts from a old Nissan minivan hatch. Ended up about an inch shorter, but will lift the hatch with the touch of a pinky finger!
In the warm days I don't even have to touch the hatch,It will pop up by it self.....I always empress the Z croud about the powered hatch.Lol.
