1980 280ZX Removal of stereo Help!!!
Old Jan 18, 2006 | 06:41 PM
nismo619's Avatar
what type of tools are u using ? sounds like u might need and ADJ open end wrench ? let me know
Old Jan 18, 2006 | 07:20 PM
you need to remove the bottom lil covers at the carpet level (use a phillips screwdriver) to uncover the lower 10mm bolts (2 on each side). You also need to remove the knee panels drivers & pass side (they have the white light on them). You will then see 2 more 10mm bolts on each side... remove all the 10mm's and you should be good to remove it. There might be several other bolts / connections... but you will see when you get the 10's out.
Old Jan 19, 2006 | 02:34 PM
tougez's Avatar
Did you buy a new mounting kit for the stereo or are you going to make your own. Its really easy and cheeper to make your own as long as you don't want to ever put the original back in.
SurgeNJ
Apr 16, 2010 02:38 PM
Casas4
Jun 21, 2008 05:54 PM
SurgeNJ
Jul 19, 2006 04:14 PM
wanta280zx
May 22, 2006 08:07 AM
JBenbenek
Oct 23, 2005 01:17 AM
