240Z, 260Z, 280Z V8 Swaps Chevy / Ford / Nissan V8 Motor Swaps
V8 Choices for 240Z
Old Mar 4, 2015 | 08:37 AM
dlirium's Avatar
V8 Choices for 240Z
Howdy All - just came into a nice 1972 240Z that currently has a Chevy 350 in it. Conversion already done, but I'd like to drop a few more HP into it. I have two questions -
1) I'm thinking a 383 with 450-500 hp would be a nice match. Since it is already setup for Chevy, i'll stay that route. What are some of the other options I should consider that are popular?
2) Engine source. There are a TON of engine builders on the internet. I know that many of them use junk Chinese parts and it will probably grenade quickly. Are there any reputable chevy engine builders that folks on the forum have had good luck with?
Thanks for the help!!
Old Mar 6, 2015 | 11:34 AM
theramz's Avatar
I have a present for you...
Your car may be "set up" for a chevy but is it set up for 500 hp? You have a lot of searching to do on the various Z forums. By the time you get set up for that much HP you will realize that you are now at the get go part. The S30 chasis, suspension, rear diff etc. will not handle that much HP.
Old Mar 6, 2015 | 01:14 PM
dlirium's Avatar
Right! I have to find out what, if anything, has been done thus far. Thanks, appreciate you getting me pointed in the right direction!!
Old Mar 8, 2015 | 06:17 PM
theramz's Avatar
And don't forget brakes!
Old Mar 12, 2015 | 01:12 PM
SpeedRacer's Avatar
GM Crate Motor
GM crate motors are pretty reasonably priced, come with a warranty and they sell some 383's.
Do you know if the conversion on your 240Z was done using the Jags That Run (JTR) method or something else? You might want to get a copy of the Jags That Run conversion manual. JTR Datsun Z Car V-8 Conversion, manual for Datsun V8
Also, you might want to check out the HybridZ site. HybridZ
Good luck.
http://www.cardomain.com/ride/236622...rrari-250-gto/
Attached Thumbnails V8 Choices for 240Z-ferrari_38.jpg   V8 Choices for 240Z-photo8.jpg
Old Sep 20, 2023 | 04:56 PM
Phantom77's Avatar
Dlirium,
What are you trying to build? Quarter mile car? Daily Driver? Crooked track/autocross car? If oyou're just wanting to go fast in a straight line then the 383 stroker is a good option. The problem is that it's weight will affect tour cars handling in corners. Also, tje 240 was know as the "flexy flyer" becasue it's unibody is so weak compared to more modern vehicles. With that kind of power you will need to structurally reinforce (full length subframe, strut tower supports, rollbar) The 240 also has an R180 differential so you'll need to at least upgrade to the 280S R200 - Best would be a Z31 turbo LSD r200 with CV halfshafts - or you could just replace stuff every time you break something which will be more often than you want.
My LS1 powered 280 has 325 HP to the rear wheels with and '88 Z31 LSD R200 but I still have u-joint half shafts and I have broken two of them.
KHCreason
Sep 20, 2010 07:44 PM
FubarI33t
Mar 23, 2007 09:17 AM
apollo
Mar 22, 2007 06:20 PM
Tuuurbo
Sep 30, 2003 06:09 PM
jburge01
Sep 3, 2003 06:23 PM
