What kind of Carb?
Old Aug 2, 2002 | 01:43 PM
Re: What kind of Carb?
Some people do put in a 2.8L engine and use the dual SU carbs from a 240Z. That runs very good. Gives a lot more torque than a 2.4L 240Z engine and a bit more than your 2.6L
as far as the 2.4L fuel injection, they are probably trying to tell you that the 1977-80 Datsun 810 and 1981-84 Datsun Maxima use a inline 2.4L engine just like the 240Z but it is running EFI. You can put the whole intake and wiring harness from that car into your Z to get the fuel injection setup. But, if you put that onto a 2.8L engine be sure to use the computer and Air Flow Meter from a 280Z or 280ZX that way you have the proper amount of fuel going in.
The carbs will not give you as much torque as the EFI. The EFI should be much more trouble-free once it is all set up, but that is usually the difficult part. Carbs are easier to change and swap around. Fuel injection is a little complicated and requires some preparation during the swap. On the high rpms, the carbs will give some more power, but that is only comprared to a stock fuel injection setup. There are a few tweaks you can do to get your fuel injection good for RPMs in excess of 5000.
FubarI33t
Sep 17, 2006 07:57 PM
phrozen209
34
Jan 21, 2005 10:24 AM
smartman3000
Mar 24, 2004 09:54 PM
DarkmoonZX
Oct 24, 2002 12:04 PM
lil_racer_tony
Aug 2, 2002 01:23 AM
