Turbo Tranny with stock engine
Old Mar 28, 2007 | 08:28 PM
duowing's Avatar
NisTuner
I had a question for you guys. I'm looking into getting a 240z. Anyway I was wondering is it worth swapping in the T-5 with the L24? Or is it better off with the original tranny? Or if you swapped in a T-5 would you want to use a different rear diff ratio? I'm just looking for people's thoughts and experiences with doing this.
Old Mar 28, 2007 | 08:42 PM
no point in it, just get a normal zx 5 spd, you wont be making enough power on the stock l24 to make a T5 worth the money or time.
Old Mar 29, 2007 | 08:16 AM
The driveshaft will have to be custom made... or basically take the turbo 280ZX driveshaft and have it shortened. Besides that it should bolt in.
You'll want a lower geared rearend, 3.9 would be fine
Old Mar 29, 2007 | 06:30 PM
duowing's Avatar
NisTuner
If you have the the T-5 and Driveshaft on hand would it be worth it?
Old Mar 29, 2007 | 06:38 PM
"Worth it" in what way? Feel? Strength? Performance? Why do you want to swap it?
I personally like the T5 a lot more than the stock n/a tranny. I installed a Mustang shifter & shortened the stick (not a true "short throw" but better than the mile high stick). Mine has held up a lot better than the n/a... Didn't Bleach have a thread on "T5 experiences?" Oh yes... here it is: https://www.zdriver.com/forums/showt...highlight=borg
Old Mar 30, 2007 | 08:33 AM
Yes, I ran a T5 behind a stock L28. It is tighter, 'newer' feeling transmission. I like it.
I only did the swap because
1. My NA tranny blew up
2. I knew I would do a turbo engine swap some day
Old Apr 1, 2007 | 08:16 PM
duowing's Avatar
NisTuner
Actually I was trying to find that thread Nismo. I couldn't remember what it was called and for some reason searching borg warner never occurred to me.
Old Apr 1, 2007 | 09:40 PM
theramz's Avatar
I have a present for you...
I think the best thing about the T5 is the lower first gear. It will help the turbo spool up faster. You will need a R200 diff or at least the pinion yoke for the earlier Zs. I have a T5 with the Mustang shifter for the L28T I'm putting together. I don't see any point in using it with a na engine but if you already have the parts, why not?
borini63
Sep 13, 2012 11:00 AM
nismo619
Mar 20, 2010 08:06 PM
DATZUN
Jun 26, 2005 01:26 PM
mark86t
FS: 300ZX (84-89)
Dec 31, 2004 06:22 PM
THE BIG ONE
May 17, 2003 05:57 PM
