Z32 engine and tranny
The na won't be nearly as difficult a swap as the TT would be. And I've seen the TT swap done personally. And it was a bitch to do. But it is definitely possible. Less hosing on the NA and you don't have to worry about the turbos interfering with anything in the engine compartment(and they will if you want to place the engine in a practical position. So I say go for it. But just remember, it's not a drop in affair. Nobldy makes any kind of conversion kit for this swap, so you'd be working from scratch. Check www.hybridz.org. They have info on any swap you can imagine. Good luck
THE BIG ONE
May 17, 2003 05:57 PM
