Starter Dead on my 260z ?
Old Jul 13, 2003 | 07:51 AM
Creator's Avatar
Hey guys, i tried to start up my 260z this morning, and she wouldn't turn, all my accesories would work (radio, lights etc), but the start wasn't moving.
So i took out my extra battery, and tried to jump it from the starter, and nothing, no noises, no movement. Is there anything else i can try to determine if i need another starter?
or is jumping it by the starter the only way to test them?
thanks
.cre
Old Jul 13, 2003 | 08:28 PM
zpeedracer25's Avatar
First I'd check the solenoid wire. Make sure you have power here when the key is turned to the run position. If you've got power you could still have as solenoid or a starter problem. Have you tryed jumpering power from the solenoid power terminal to starter power terminal? If jumpering doesn't work, then I'd replace the starter. Good luck.
Old Jul 14, 2003 | 06:48 AM
Creator's Avatar
i tried jumping directly from the starter posts. avoiding the solenoid, and nothing.
and i've already called around to a bunch of auto parts places, these starters are not easy to come by.
thanks
.cre
Old Jul 14, 2003 | 07:12 AM
thanks
.cre
Ummm....maybe I'm reading this wrong. By jumping to the starter posts for power and ground you're only eliminating your battery cables from the equation and nothing more.
Old Jul 14, 2003 | 08:30 AM
Creator's Avatar
What does the solenoid look like? i noticed there was a little box ontop of the starter, with 2 wires on it. is that what yer talking about?
Thanks
.cre
Old Jul 14, 2003 | 11:22 AM
Thats it. You should have 3 terminals on it. One for the positive wire from your battery, one that goes directly into the starter and one that has a smaller wire going to it. I think you can bypass the solenoid if you jumper power to the wire that enters the starter.
Old Jul 14, 2003 | 11:37 AM
Creator's Avatar
Cool, i'll give that a shot when i head home tonight, Thanks alot
i'll letcha know either way
.cre
El_Colombiano
Jan 18, 2013 03:36 PM
Sweets
Feb 8, 2010 06:49 PM
WildmaN
Sep 19, 2009 07:46 PM
AlongCamePeter
Sep 12, 2004 06:20 PM
Kirie_260Z
Mar 6, 2002 11:09 AM
