Skyline Engine On A 1971 240z
Old Sep 20, 2003 | 10:42 AM
Creator's Avatar
i was planning on doing the same swap, all you should need to do is, swap the oilpan with the one on yer block already. the skyline6 has the bulge too far forward..
the exhaust manifolds on the skyline6 should work fine, and the motor mounts should bolt right up. but if you plan on using a 6speed tranny you may need to get yer driveshaft shortened.
good luck
.cre
Old Sep 20, 2003 | 12:23 PM
auxilary's Avatar
the Dude
well, both of you are wrong
http://www.highrpm.org/howto/rbmotors/
Old Sep 22, 2003 | 10:02 PM
theramz's Avatar
I have a present for you...
burst your bubble
This is probably the greatest swap you could ever do except for one thing, well alot of things. Should you take a chance that an 8 year old racing engine and trans such as an RB25 with 30k plus miles on it has been driven without being raced? What about the last 5k miles when the owner knew that the engine had to come out anyway? How would you drive it if it was yours? Personally, I would drive the **** out of it! It's not like you can go down and get a new set of rings or bearings or even a clutch for it at the local Nissan dealer.
Be careful who you buy it from. I've seen ads where they claim that the engine has been compression and leak-down tested but they don't tell you the exact results. A 30 day warranty? How long do you think it will take to do the swap? The warranty is to "run" not smoke the tires in third! My guess is you will put another 4k on top of what you already paid. Do your homework first. If you suceed please let us all know.
Old Sep 23, 2003 | 01:53 PM
texasz's Avatar
Look at hybridz in the L6 forum, there are several people who have done this swap already and should be able to provide lots of help and insight.
ZedHead93
Jan 5, 2014 11:15 AM
mhough326
Oct 21, 2008 04:48 PM
ericshere03
Jan 18, 2008 10:51 PM
Superduner
Aug 27, 2007 04:00 PM
zz240zzl24
Jun 10, 2003 11:49 AM
