runs than died
Old Jul 15, 2008 | 08:30 PM
luckyZ13's Avatar
runs than died
hey everyone! Ihave a 77 280 that seemed to be running perfect. Just lost all power from the engine. Everything else works,lights etc. getting spark and fuel also. any ideas?
Old Jul 15, 2008 | 09:05 PM
280zx2by2's Avatar
Haterade by da gallon!
compression? Timing? check check check check!!!!
you dont have any clicking or tapping do you? hope to god your timing chain didnt slip of fall off.... but i have only heard that happen very rarely(good ole reliable timing chains....)
also whats the story? you were driving down the street and????? or you were changing the distributor cap and?????? or you were doing a burn out and?????? when did it quit working?
Old Jul 15, 2008 | 09:26 PM
n e e d m o r e i n f o . . .
Have you tried restarting the car? If it's getting PROPER spark and PROPER fuel... it's likely flooded.
Old Jul 15, 2008 | 09:34 PM
luckyZ13's Avatar
runs then...
i was just driving about 30mph and she just quit. been about two hours,got it towed home and it started right up. did the same thing about a week ago. ran good since till today.
Old Jul 15, 2008 | 09:52 PM
Hmm...maybe your ignition control module? Kind of sounds like the symptoms. It is located on the distributor. That could be going bad...and that causes your Z to run. Until the module gets warm...then it will not start until. It gets cooled off. Am I off...or close?
Old Jul 15, 2008 | 10:20 PM
luckyZ13's Avatar
yup
sounds about right! where exactly is the module? expensive? easy to replace?
Old Jul 15, 2008 | 10:23 PM
280zx2by2's Avatar
on the distridutor and it can be expensive... i dont know what the price it for a 280z is though
i had the same problem so i changed my icu and pick up coil and it hasnt done it since
oh and wildman mine got so bad it would do it even right after i started the car when the motor was cool... its a big problem for cars and trucks made in the 80's
Old Jul 15, 2008 | 10:32 PM
luckyZ13's Avatar
k
i have a 76 parts car/project. would that one work on my 77? thanks for all your help everyone!
Old Jul 15, 2008 | 10:43 PM
280zx2by2's Avatar
probly ... but im a zx guy
Old Jul 15, 2008 | 11:20 PM
duowing's Avatar
NisTuner
Yeah, it's the same engine so it will swap right over.
Old Jul 16, 2008 | 01:56 PM
luckyZ13's Avatar
thanks
thanks all for your help
shaved300zx
Aug 22, 2009 05:40 AM
livinzlife
Aug 29, 2007 07:46 PM
FubarI33t
Nov 29, 2006 11:37 AM
jesusfreakz
Oct 20, 2003 03:02 PM
ContagiouSzxt
Aug 11, 2002 03:29 AM
