Running horrible - Back from the dead
Old Apr 9, 2012 | 08:34 AM
Fast240Z's Avatar
Sup guys, I'm coming back out of hiding for a while. Z has been parked since November 2010 as it started running like garbage, so I bought a 2010 Civic new off the lot as my new DD.
I started the Z up the other day and went for a drive, but it wasn't as pleasurable as I would have imagined. She's stuttering under acceleration, similar to an ignition misfire. I've replaced the cap, rotor, coil, spark plugs, and plug wires, but the issue still persists.
I notice that if I add more choke, the stutter begins to disappear a bit, but is still present under WOT. Since choke adds more fuel to the mixture, I turned my carbs out a turn more, which made the stutter less noticeable, but still present under WOT as before.
Any ideas as to what else needs to be tweaked? I know I need to buy a set of ZTherapy carbs sometime soon as the current carbs are incredibly worn. A new distributor is also on the list of parts to replace, the advance on mine doesn't seem to work reliably.
Old Apr 9, 2012 | 09:28 AM
Hopefully you're not running the 2+ year old gas... it's probably goo'd up varnish getting sucked through the carb's... which also need to be cleaned.
Old Apr 9, 2012 | 09:36 AM
Fast240Z's Avatar
Nope, not old gas. I put a new tank in to ensure the fuel was good. If it helps, the stuttering/misfire feeling was occurring before I parked the car.
chicopriest
Nov 30, 2017 09:00 PM
WildmaN
Jan 1, 2006 11:53 AM
duowing
Nov 21, 2005 02:24 PM
mm107
May 15, 2005 04:57 PM
Darrel
Jun 15, 2001 06:14 PM
