Rear end clunking
Old Sep 4, 2003 | 10:29 PM
zpeedracer25's Avatar
The most common cause is worn out mustache bar bushings. That or you have a worn out u-joint in your half shafts or drive shaft. If you don't have a problem with vibration, its probably the mustache bar bushings. My 280Z had the exact same problem and that was the problem.
Old Sep 5, 2003 | 06:54 AM
I'm not really sure if the manual refers to it as a "mustache bar". Its the rear most mount for your differential and attaches to the differential cover and then to the car. The suspect bushings are the ones where the bar mounts to the car. I replaced mine with urethane ones and that solved my problem.
Old Sep 5, 2003 | 10:10 AM
auxilary's Avatar
the Dude
actually, the most common cause of the clunk is a torn differential front mount.
Old Sep 5, 2003 | 10:47 AM
Ooops, overlooked that one. The ones I've seen don't clunk until it wears out the mustache bar bushings also, allowing the front of the diffy to swing up under acceleration. I've seen a nice replacement on Hybridz.org I believe that mounts over the top to the diff in the front to stop the upward motion. I need to build one of those for my turbo car
Old Sep 7, 2003 | 09:51 PM
theramz's Avatar
I have a present for you...
It's worth keeping!
the dude is right! The diff clunks when you let off because it sticks up when you accelerate and when you decel it slams back down over the rubber. Try prying up on the front of the diff with a crowbar. It should move up only a little and recover when you let loose. Motorsport Auto sells them for $44.02. While you have it out you might as well do the urethane bushing replacements too. Be sure to let us all know how you make out. Good luck.
zcrazy13
15
Jun 5, 2019 12:22 PM
PredatorZ
Mar 18, 2014 04:36 PM
Z_lover
Jun 19, 2008 09:19 AM
Skully
Mar 20, 2002 03:40 PM
Zpeed
Jan 2, 2002 02:56 AM
