PO cut the fuel rail?
Old Oct 1, 2014 | 09:43 AM
Pez's Avatar
Pez
Didnt really notice this before until I started this year's fall Z project, but the PO has hacked the fuel rail:
The masked nibs you see there are (from right) #1 and #2 injector. You cant see in the pic, but there are marks from a hacksaw where he took a couple tries at it. Perhaps he was impatient and was trying to take it off and decided to hack saw it. Anyway, these two cuts are not supposed to be there per the FSM, and if they were, they would have the proper nib style ends to securely hold a fuel line clamp.
While I'm not too concerned about leaks (it hasn't leaked in the 24 months I've owned it), I am a bit concerned that here is a section of fuel rail that is not secured to the manifold by anything other than two short pieces of fuel line hose.
If this was your L28, what would you do, if anything?
Old Oct 1, 2014 | 11:53 AM
PredatorZ's Avatar
2 options
I would say there are 2 ways to go here, find a stock "trombone" fuel rail and use it, or have a custom rail made. Not sure if a rail from an 81 280zx would be compatible with your car, but I will soon have one available, I have ordered a custom fuel rail and it will be ready and shipped in the next day or so, so after I install it ill have no need for the old one. Not sure of the fit, perhaps Nismopick or one of the other Z guru's could give a definitive answer, I would give it away for just shipping charges, say about $ 20 shipped. Tips are excepted, you can always donate to my favorite charity "me"....
Jeff Thompson is the guy fabricating the rails, not sure what his sign on is here, but he is in several FB forums, like https://www.facebook.com/groups/164690436882353/
Old Oct 1, 2014 | 02:11 PM
Pez's Avatar
Pez
I see what you are saying, but if I can beg the question a bit, WHY does it need replaced?
A large question is WHY did PO cut it in the first place, but he long ago stopped responding to my texts....
Old Oct 1, 2014 | 10:36 PM
PredatorZ's Avatar
reasons
I would say one reason, or concern with a rail in so many pieces, it just adds to the amount of possible connections that can leak, if all you need to do is put a few short pieces of hose in to get it all working, and you are good with that, it should be fine. I can kind of understand why it was cut up, when I 1st got my car, a lot of the rubber lines needed replacing, taking the fuel rail off in one piece involves removing a lot of stuff, it was most likely done in frustration, to speed up removal. You might want to get a flare tool, put some flares on the cut ends, so you don't have a fuel leak.. which turns into a 3 alarm fire.. bye bye car at that point. More of a safety issue if not done properly, that would be my major concern really, no leaks !
Old Oct 2, 2014 | 05:45 AM
Pez's Avatar
Pez
Yea, I will see about making some proper ends. It seems odd to me that I never noticed the extra set of hoses before. Now is the time to do it since I have the manifold and rail off.
Cheers.
Old Oct 3, 2014 | 05:39 PM
Turksspeedwerks's Avatar
I got a 280 fuel rail I'll give you as we'll I'm going aftermarket too just pay shipping and it's yours
Old Oct 4, 2014 | 07:56 AM
Pez's Avatar
Pez
Fantastic! PM sent.
Old Feb 8, 2015 | 08:08 AM
k5ride's Avatar
new to z driver
Where can I find an aftermarket fuel rail setup for my 260z? I'm running dual webers and need a show quality fuel line / rail. I don't mind making one but due to time restraints, I would rather just buy one ouright. I appreciate any suggestions, ideas, pics or information. Thank you for your help.
Old Feb 9, 2015 | 07:04 AM
theramz's Avatar
I have a present for you...
Go here Braided Stainless Steel Lines
and make a real nice fuel feed for not much $.
Old Feb 9, 2015 | 07:13 AM
Steve260Z74's Avatar
I haven't ever heard of anybody making a fuel rail for a dual Weber setup. They were usually just plumbed in with the stock fuel rail. The problem with an exposed fuel rail is that you'll pick up heat from the exhaust, and you might experience vapor lock. It's less likely with the Webers, but it could still happen depending upon your mixture and how well you're getting heat out from under the hood.
If you want one, you'll probably be making it out of stainless.
Old Feb 9, 2015 | 04:27 PM
k5ride's Avatar
Thanks for the suggestions and link.
zdrifter91
Jun 11, 2014 11:16 AM
ericeel
May 25, 2014 10:29 PM
83ZXGurl
Jan 22, 2012 03:23 PM
SHADY280
Mar 8, 2006 04:30 PM
WildmaN
Dec 12, 2005 09:21 AM
