OIL PRESSURE HELP
Old Oct 24, 2002 | 01:40 PM
Re: OIL PRESSURE HELP
Are you sure? didn't he say they hooked up a manual oil pressure guage?
I think he is telling us his engine really only has 10 psi ! That is not good. if so, you might need a rebuild. Most likely place to loose pressure is the bearings on your crankshaft, right?
Old Oct 24, 2002 | 06:30 PM
Spudz's Avatar
When I went to synthetic oil my gauge really read low.
I kept opening the oil filler hole and checking for oil
on the top end [img]/w3timages/icons/smile.gif[/img]
I think 10 psi isn't to bad on an older engine like ZR8ED
said. Did they run the RPMs up to see if the gauge went
higher then 10psi ?
Old Oct 25, 2002 | 08:39 AM
Well, ok. If you say so.
My n/a ZX has 202,000 miles and I'm using the original oil pump. I did put in a new sender unit but my pressure is in the middle of the gauge at idle and near 80 at higher rpm. Same thing with the other ZX I had. Both cars had a bad sender. It is true that it goes out a lot. $50 from Nissan.
I hope that it is only a bad sender and not actually an oil pressure problem. If the engine is not knocking, then you're probably ok.
FubarI33t
Apr 27, 2010 08:45 PM
FubarI33t
Dec 12, 2009 10:03 AM
tonsoffun300zx
Sep 21, 2009 10:51 AM
y2daniel1981
Oct 25, 2006 10:24 AM
91zxtt
Mar 5, 2004 11:00 AM
