NOW IT RUNS! (was:ARGH! Now it doesn't run at all)
Guest
Posts: n/a
Hey guys--- I figured out why the car died--- I guess 1 gallon isnt enough in the tank for it to run well. I put in about 5 gallons and it ran fine... BUT while messing with the wires by the voltage regulator, and doing to chg system testing, the engine died (when I took off the + cable to see if it would stay running) and now won't start at ALL! It's getting spark-- if I spray some starter fluid in a vacuum line it fires--.
I swapped the CPU with a spare, and that didn't cure the problem.. I checked ALL the wires and fuses and connectors--- no luck. Any ideas?
-Steve
-Steve
http://hometown.aol.com/stev240z<P ID="edit"><FONT class="small"><EM>Edited by stev240z on 08/21/02 03:14 PM.</EM></FONT></P>
-Steve
-Steve
Guest
Posts: n/a
Re: ARGH! Now it doesn't run at all!
there's pressure, and the pump is getting power... all the fuses are OK
-Steve
-Steve
Guest
Posts: n/a
no, I dont think its that serious--- if anything I'll put my carbs on and that'll be it
i want the FI to work though
-Steve
-Steve
Guest
Posts: n/a
Ooh, you have a FI now, What are you planing to do wth your Carbs?, i am looking for some SU's for my 260z, i will buy them off of you if there are at a good price.
-tony-
1974 junkyard 260Z
100% Junk Will be restored to a new car by next year.
-tony-
1974 junkyard 260Z
How about the coil, plug wires and spark plugs? I found that my car wouldn't start if the coil wire was pinched a little out of place since the wiring was so old.
82ZXT
82ZXT
Guest
Posts: n/a
NOW IT RUNS!
Turned out when I took the positive terminal off when the engine was running i fried the ECU. A trip to the junkyard today and $31 and its fixed. Thanks for the advice everyone!
-Steve
-Steve
shaved300zx
Aug 22, 2009 05:40 AM
ContagiouSzxt
Aug 11, 2002 03:29 AM
