now im really freakin confused
Guest
Posts: n/a
i started the engine and disconnected the vac line to the ac thing at the manifold. the idle picked up a 100 rpm or so and the idle was much better, but that is a vac leak so i plugged it cuz in a normal working system it will be limited. also disconnected the egr to test my idea. the engine seemed to run a little longer than normal but it still hits normal temp, runs for a while and slowly sputters to its death.
im so frustrated with that car, i was gonna start drivin it in june, it has been down since then.
thanks for all your help,
jeff
jeff
Re: now im really freakin confused
Jeff,
checked on a few of your last posts. One question, have you checked your coil ? Sometimes when it gets hot under the hood it will fail till it cools a little. Just a thought
Guest
Posts: n/a
Re: AFM
the web site http://manuals.type4.org/ljet/ was referred to me by someone on zcar.com. it would appear that my z is running a little rich, and someone mentioned the AFM.
the site mentions something about contacts in the AFM that are related to the fuel pump. does anyone know about this???
thanks
thanks
trezo
Mar 13, 2005 09:33 PM
