need a mechanic!!!
Old Apr 21, 2008 | 04:44 PM
luckyZ13's Avatar
need a mechanic!!!
need a good mechanic in phoenix az. area to tackle some things i'm not up to. Any suggestions? 77 280Z 2+2
Old Apr 21, 2008 | 04:46 PM
We have a few people in AZ... but maybe you could expand on the problem first?
Old Apr 21, 2008 | 04:58 PM
luckyZ13's Avatar
sure. i need my timing chain adjusted. i don't think it's ever been done and i'm pretty sure my motor is original. i also need all the bushings replaced. they are in terrible shape.
Old Apr 21, 2008 | 05:03 PM
L-series motors RARELY need the timing chain adjusted as the double wide chain is very durable. These motors can go 300k on original parts if taken care of.
Why do you think you need the timing chain adjusted? Have you checked your timing?
As for the bushings... oh yeah!!! The stockers will rot, and crack, and creek...
Old Apr 21, 2008 | 05:04 PM
luckyZ13's Avatar
need timing chain adjusted and bushings replaced front and rear
Old Apr 21, 2008 | 05:05 PM
See my previous post...
Old Apr 21, 2008 | 05:08 PM
luckyZ13's Avatar
my performance doesn't seem to be what it should be. i adjusted my valve lash a coupl weeks ago and was trying to figure out the markings on the cam sprocket and from what i gather from my chilton it needs a turn to the two or three. I'm a little confused on the whole thing. the bushings are just flat toast!
Old Apr 21, 2008 | 05:10 PM
So... yeah...
Have you checked all the basics?
-Plugs
-AFM
-Timing
-TPS
-Cap & rotor
-Injectors
Old Apr 21, 2008 | 05:15 PM
luckyZ13's Avatar
timing looks good and my afm is new as well as my injectors cap rotor and plugs. fuel pump and filters and regulator are new also. doesn't seem to want to go. it does run good though.
Old Apr 23, 2008 | 06:31 PM
Ratfink's Avatar
Hoov for Pres!
I am pretty free tomorrow and Friday morning. I am a heavy diesel technician for Empire. I don't have a shop, or a good place to work on your car. 90% of my tools are at work. So I don't think I can be much help with replacing all of your bushings. But, I am willing to help diagnose your engine performance issues. No pay. If you pay me, it will feel like work, and I am likely to call in sick. lol
I would not jump in and think that you need to adjust your cam phasing. The chains last a long time, and they should not need adjustment. But, the chain can stretch to the point that the cam timing it out. As said before, these are stout chains for these engines.
If it does need to be done, then I can help. But, I don't want to do the whole job. I am not trying to get work here. I don't need it. I have too much as it is. Not the mobile mechanic type, and I already have a ton of friends screaming for help with projects.
I am willing to bet, that with minimal hand tools, and time, that would be a project that is easily tackled by a do it your-selfer. All it takes to be a good home mechanic is the time it takes to read up on the job. You're goal is not speed of work, but quality. Plus, this job only requires one special tool I can think of, and a puller can be borrowed from your local Checkers.
I will send you my cell phone number.
Give me a call, I'll make some time to help a fellow Z owner out.
Old Apr 25, 2008 | 08:21 PM
Ratfink's Avatar
Hoov for Pres!
Well.. I am going to be gone on a short trip, then to work for 7 days after that.
Let me know if you want some help, I will be back to the normal world around the 8th of May.
Not to imply that anything in the world is "normal". =)
Old Apr 25, 2008 | 11:24 PM
duowing's Avatar
NisTuner
What is your timing set at? Did you actually set it with a timing light, and marking the timing plate and the notch on the pulley with whiteout? Also you probably have vacuum leaks, my car would run fine, but had a lot of power issues do to vacuum leaks.
Old Apr 29, 2008 | 02:15 AM
Ratfink's Avatar
Hoov for Pres!
Saying that someone "probably" has a certain problem because you experienced it is difficult. That is a lot of variables when it comes to making power with what you have in an engine. There could be several factors that are missing. You just have to pick an area that is likely with the given problem, and work your way up. Air, Fuel, Timing, compression, and spark. If they are all working like they should, then you will have 100% of the power available through the components used.
Old Apr 29, 2008 | 05:50 AM
theramz's Avatar
I have a present for you...
Instead of paying $75-$100 an hour you could download the entire factory service manual from carfiche.com. Get a multi-tester and check all your sensors including the "new" afm per the manual. You can advance the cam by removing the sprocket and repositioning it being careful not to drop the chain. If you can adjust the valves this is all just time. Now udamakanic!
Old Apr 29, 2008 | 11:31 AM
Ratfink's Avatar
Hoov for Pres!
Just zip tie the chain. You can keep it from falling easy.
Old May 4, 2008 | 10:57 AM
Ratfink's Avatar
Hoov for Pres!
So how did this work out? I am coming around on my week off again, and could schedule some time to help a Z driver out.
Old May 5, 2008 | 08:34 PM
SpeciallySpiked's Avatar
I'm a Registered User!
Sorry I don't have any answers for you as I perform all the work myself. (Including things I probably shouldn't)
But it's awesome to see there are some older Z's out there. This summer, I'm fairly convinced I was the only 280ZX on the east coast. Especially when I was in NYC.
You're going to have some awesome stares! Let's see those pictures!
dcoop46
Aug 7, 2015 08:54 AM
vonster
Jul 29, 2014 11:21 AM
zbutch
May 22, 2011 11:13 AM
KirkAlford
Oct 28, 2006 08:44 PM
zcrazzzy
Northeast Region
Jun 28, 2005 01:20 PM
