Lightened flywheel
Old Oct 23, 2001 | 10:58 PM
GodZilla's Avatar
Banned
Lightened flywheel
What are the major benifits of a lightened flywheel?
I know it allows the engine to spin up faster due to less weight but would it add an increase to pwr at the wheels?
Old Oct 24, 2001 | 01:24 PM
Ghostz's Avatar
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Re: Lightened flywheel
Godz,
A lightened flywheel has several advantages and disadvantages.
Pros,
The most noticable is that your engine will rev up considerably faster. This is due to rotational mass (or inertia or whatever they are calling it), or loss there of. When a 10 lb. flywheel spins at 5000 rpm, it creates added mass to your driveline. When a 5 lb. FW spins at that same speed, it creates half of said power robbing mass. If your car is turbocharged(I'm assuming not) this really helps to spool the turbo up faster.
A LFW also produces less stress on your crank and bearings, as they don't work as hard to spin it. They don't PRODUCE more power, they just free up more power to the ground. They also smooth out your idle.(if you have a good one)
Cons,
If your FW isn't properly lightened, you get crappy idle.
As well as speeding up your engine in revving up, it also speeds up the other way as well. As in, when you are going up and down hills, you use more gas.
I wish I had one in, my brother got one in his Rx7t and it is awesome!
Ghostz
Old Oct 24, 2001 | 01:28 PM
Ghostz's Avatar
forgot,
here are some numbers
http://www.metricmechanic.com/pgs99.htm
ghostz
Old Oct 24, 2001 | 03:19 PM
silvrhand's Avatar
Snazzy Title
One thing to also worry about is driveability, as when you lose mass on your flywheel you lose the stored energy (momentum), so basically you have to rev higher to get smooth launch as when the clutch engages it no longer has mass it once had.
This isn't a problem for street discs but if you ever go to an unsprung clutch it'll be really hard to launch smoothly..
There are better ways to free up power if you ask me.. A lightened driveshaft will also help if you have a solid steel one.
Lot cheaper and easier to put in too.. Of course it won't be long before you start on that go fast crack pipe eh!
puff puff gurgle gurgle.. 60 shot nos..
puff puff gurgle gurgle.. supercharge/turbo kit
hehe it gets worse the faster you go I think..
- john
Old Oct 24, 2001 | 10:33 PM
Ghostz's Avatar
I hear its gonna snow..............................
Old Oct 25, 2001 | 06:29 AM
silvrhand's Avatar
Snazzy Title
ugh snow no, time to put the blanket on my baby and tuck her away till it clears..
- john
Old Oct 26, 2001 | 10:51 PM
Ghostz's Avatar
As in Godzilla is gonna hit the evil snowball factor(as if he hasn't already -...lol
Ghostz
Old Oct 27, 2001 | 10:20 AM
GodZilla's Avatar
Banned
ahhh hehe n/m
n/m
Old Oct 28, 2001 | 12:20 AM
Ghostz's Avatar
Re: ahhh hehe n/m
Really?! Sweet car though, well worth it
BLKzxTT
Mar 28, 2014 09:20 AM
Anferno
Aug 12, 2013 11:34 PM
domsgarage
Apr 13, 2010 08:24 PM
Heat Rave R
Mar 20, 2007 01:01 AM
sion
May 4, 2006 04:26 PM
