Just bought '77 280z!!
Old Jan 23, 2004 | 06:00 AM
  #102
zr8d's Avatar
you can just use some mesh behind the spoiler there like the imports use. it looks pretty good. the only problem you run into is that it will probably clash with the stock grille on there now. so you'd probably want the replace that with mesh as well. it's real cheap and looks pretty good. is that body kit fiberglass?
Old Jan 23, 2004 | 08:19 AM
  #104
zr8d's Avatar
well, i know you hate adhesives but that may be the only way to get a grille or cover for that. can't weld on fiberglass and rivets won't look too good.
Old Jan 23, 2004 | 09:35 AM
  #106
zr8d's Avatar
sounds good. that should look really good once you get it done.
Old Jan 24, 2004 | 05:51 AM
  #110
zr8d's Avatar
i feel your pain. i've had to replace a clutch in the honda last week in 20 degree weather without a heater. it sucked azz.
Old Jan 24, 2004 | 08:03 AM
  #111
zr8d's Avatar
hey wolff, what search criteria did you use when you found those spark plug wires? i can't find any under "280z" and when i put in "8 mm spark plug wires" it only brings up v-8 wires.
Old Jan 31, 2004 | 02:41 PM
  #119
zr8d's Avatar
things sure do work a lot better when you follow those damn instruction thingy's, huh.
Old Jan 31, 2004 | 03:36 PM
  #121
zr8d's Avatar
i AGREE.
