Im a NEWB here and would appreciate some help on my build
Old Apr 24, 2011 | 06:11 PM
pretz_meng69's Avatar
alright so i have a 74 260z and everything is stock which im not planning on keeping for awhile. I do not want to swap the L26 out but just make it faster.
I was wondering if anyone of you know if the "p90" head and 280zx oil pump will fit on the L26???
another question i have is to upgrade the SU carbs as well but everyone has the 3 weber DCOE set up so I am planning to go the other way. what other set up would produce some power???
any ideas on where i can get some lowering springs that will drop my car 3in. or more???
if you have any ideas on how to make the L26 faster.... all ideas are welcome but if your just going to tel me to swap then no thanks..... well at least not yet......
PLEASE HELP
Old Apr 24, 2011 | 07:39 PM
Welcome to ZDriver!
Yes... all major components of the L-Series motor are interchangeable as long as you use the appropriate related components to make it function properly.
Good reads on L Heads:
http://zhome.com/ZCMnL/tech/head.htm
http://datsunzgarage.com/p79/
http://datsunzgarage.com/p90/
Normal "performance" springs will lower the car about 1" from stock. 3" would require either cutting the springs, or going coil over.
Old Apr 24, 2011 | 10:52 PM
Thank you for the info of the link you gave me it was very helpful to make my decision on going for the N42 head.... i really appreciate it.
another question if anyone can answer this. What would i need to get and do to swap in an N42 head to an L26 block??? like oil pump and other parts???....... which way should i go???? the way of the 3 weber carbs.... or the 4 barrel carb set up??? which one will get me not just more HP but torque.....
Old Apr 25, 2011 | 09:53 AM
you are asking for to much on those carbs, no one can tell you but both are a comparable upgrade. as for the head you just need a complete head and I'd do the timing chain and new head bolts/thinner head gasket.
Old Apr 25, 2011 | 12:16 PM
thanks for that info. it helps alot. and in the process on getting the head now. but I'm still in a debate for the carb. i have no clue on which way to go with it.... thanks for the help. any other ideas for making it faster without swapping??? exhaust system are done already.... and planning to get some msa stage 2 cams.
Old Apr 26, 2011 | 01:24 PM
theramz's Avatar
I have a present for you...
I read somewhere you have to "notch" the cyclinders for the larger valves of the 280 heads. The 260 bore is even smaller than the 240. When you change cams you need to replace the cam lash pads or you will void the cam warranty. That tired old motor is not going to hold up very long to all that bolt on stuff.
Old Apr 27, 2011 | 12:02 PM
yea i know i just read that a day or so ago. it sucks bc i really like the L26 but now I'm thinking of swapping it but no clue to which engine. no american engines tho.... any suggestions on the swap??? other than the RB and SR bc that one is obvious already....
Old Apr 27, 2011 | 09:26 PM
Originally Posted by pretz_meng69
any suggestions on the swap??? Other than the rb and sr bc that one is obvious already....
L28ET swap.
anniversary_Z
Mar 11, 2011 04:36 PM
Zetto
Oct 25, 2008 10:47 PM
Seeing Double
Jul 11, 2007 09:08 AM
twin ta tas
Jun 12, 2006 05:59 AM
chicopriest
Jun 8, 2006 08:30 AM
