Ignition stuck in 'lock' position s30
Old Jul 1, 2016 | 02:20 PM
camacho280z's Avatar
steering wheel not locked but i cant put 'lock' to 'off'
any ideas?
thanks
Old Jul 5, 2016 | 09:54 AM
beg3yrs's Avatar
The following is just kind of a series of thoughts, trying to see if something becomes obvious...
Physically the steering wheel gets locked by a metal bar being inserted into a hole in the column. When move the switch to the lock position, the bar is released but if the column isn't lined up just right, it won't go in until the wheel is moved just a bit.
You say the steering wheel still turns. Does it turn all the way or just a little? If it turns all the way, for some reason the bar hasn't released.
When the steering wheel is locked and there is pressure on the column, sometimes the switch gets frozen because of pressure on the bar and it can't be pulled back into the mechanism. A little jiggling of the wheel while trying to move the key usually solves that.
Have you recently messed with the mounting of the key switch assembly?
At some point you may end up simply removing the assembly and investigating further. I had one freeze up on me with the key stuck in the lock. Ended up buying a whole new one from RockAuto - turns out it wasn't very expensive, probably less than it would have cost me for a locksmith.
Old Mar 25, 2019 | 06:42 AM
oliviaBelings's Avatar
I never messed with such kind of door lock problems, have worked in locksmith irving team from many years but doesn't come across such problem.
Old Apr 15, 2019 | 08:43 AM
johnreed's Avatar
Whether you worked or not but these kind of problems are common and faced by almost everyone. So one have to call a locksmith to resolve lock problem.
Old Aug 12, 2020 | 08:18 AM
JaydenHane's Avatar
Rockauto seems to be very expensive, you must have considered contacting a locksmith at that moment.
Old Aug 24, 2020 | 06:35 AM
JuniorDala's Avatar
If you remove the assembly on your own and move to the further step but after moving you need help from a locksmith because you can't operate the stuck lock manually on your own.
yamahondarider
Nov 19, 2013 06:43 PM
KptClutchZ
Sep 26, 2009 09:27 AM
JoeGasm
Jun 14, 2009 01:12 PM
magusat999
Dec 31, 2003 01:46 PM
rick458
Sep 18, 2003 09:21 PM
