I need help changing to a Carburetor - 78 280z
Old Jan 2, 2004 | 12:48 PM
auxilary's Avatar
the Dude
if you're swapping to carb, easiest thing to do is get a stock set of SU round top carbs with stock intake manifold. you will need to procure a set of choke cables, yank out your ecu, and probably not use half of your wiring harness. everything forward from the intake ports can go in this case.
Old Jan 2, 2004 | 02:37 PM
auxilary's Avatar
the Dude
weber dvg/a 32/36 carbs
Old Jan 5, 2004 | 01:40 PM
You will need to change your fuel pump and not use a pressure regulator. For the 4-barrel, you'll probably utilize the return fuel line. A carb fuel system runs about 3-4 psi where the FI runs about 40psi. Use a fuel filter for carbs.
Old Jan 6, 2004 | 10:39 AM
Carbs dont' use a regulator! That fuel injected pump will be pushing way too much pressure I believe. A fuel pump meant for carbs pushes through the same size tube, but at a much lower pressure and they use a simple valve and floats in the carb to "regulate" the fuel level in the bowl. The rest just goes through the return line. You may be able to use your current fuel pump but its probably not a good idea. You may end up flooding out. ummm... do some research into how carbs work. You'll understand.
Its easy too. Just get the electric fuel pump from a late 240Z or 260Z.
Old Nov 23, 2014 | 06:06 PM
Doug Horvath's Avatar
4 Barrel 280z
I've done it and it's easy... I even used the original plenum, just cut a hole in the top and built my own adapter. The fuel pump can be used, just use the return line to take the pressure off. Put a crimp in the return line if you need more pressure, no problem. The whole of the FI elec wiring can be trashed w/o issue. I agree w/ the thought of the "kick" from the secondary cause it is very cool and your z will take off. Here is a pic of the install. cool... ckya dj
Old Nov 23, 2014 | 06:51 PM
ken99's Avatar
I think in 10 years, all of these guys would have figured it out...or moved on.
Z Car Barbie
Jan 3, 2009 03:35 PM
Zach280z78
Nov 29, 2005 10:40 PM
Fast240Z
Sep 16, 2005 08:55 PM
RetiredZman
Nov 4, 2004 12:14 AM
zerath
Australia
Oct 10, 2002 03:56 PM
