I have some leads...
Guest
Posts: n/a
Ok, I have been looking around at some of the bone yards around here and found some good potential.
1. (2) 280 z cars different years 1 and 1/2 engines, no tranny, minimal rust, interior shot, no glass, no tires or rims, and various missing parts. $300 + $50 for delivery
- or -
2 (3) 280zx turbo cars three engines, three trannys, all body parts, two are t top, minimal rust, rims and tires fair, interior to be desired. no offer yet
all of these are 2 + 2 and are in workable (not running) condition.
My plan is to gut everything, strip and paint, restore body, and modify the engine for top drivability and speed (slightly over the legal limits).
If you had these plans what would you pick?
Ditch the set of two, and take the three if a reasonable price is set?
or forget the three, Start from scratch with no parts bin to pull from?
peace
- or -
peace
Re: I have some leads...
If you can...
buy the 280Z with no engine, and try to get one with less rust. Pay more attention to the body and if you can buy it cheaper without the engine do so. Then buy the 280ZX turbo that seems to have the best engine and least amount of miles. Put that engine into the 280Z.
Guest
Posts: n/a
What sort of mods would need to be done if I were to swap?
If I have one of each 280z and 280zx turbo would the engine tranny combo from the zx bolt strait to the rear diff using a stock driveshaft, will it mount using the same engine and tranny mounts, ecu and wiring harness, breaking system, etc?
thanks for the reply.
peace
peace
Well, that swap is one of the easier engine swaps. The only thing easier would be swapping from a 2.4L to a 2.8L in a 240Z with carbs. but yes, the engine will bolt right up to the 280Z transmission, or you can use the 280zx tranny. ( I have heard that the ZX transmisison is longer, but I have also heard that it is the same length ) The ZX Turbo 5-speed is a Borg Warner T5 transmission and does have a different output shaft. Therefore you will have to use that part of the shaft and have it connected to your existing driveshaft. The 280Z transmission should do fine. (hopefully it is a 5-speed) Look for a more detailed writeup on this on the internet.
The engine mounts are the same which is another reason the swap is easy. The wiring harness is different as well as the turbo computer. But since the 280Z has its own harness, you just remove it and re-install the turbo harness along the same lines. Not everything is the same of course. The turbo engine has a few more sensors to connect and it has some outputs to extra guauges. You might want to install aftermarket boost guage and oil pressure guagues anyway. Besides that, there isnt' a whole lot of custom work to do, just some figuring out.
There are many pictures on this board of the first gen Z's with a turbo engine in it. Check out the rides section at the top of the screen. 70-78
After you have it in and driving really good (after your tune-up) you can do some research into turbo upgrades, intake/exhaust upgrades ect to get more power.
