Heater/Water Hose problems
Old Sep 1, 2001 | 03:04 PM
BigE's Avatar
Hi,
I need some help, I have a 1983 280ZX non-turbo. I have sprung a leak in the one of the hoses going to the heater core. I finally found a diagram for the hoses going to the heater core but not sure what the fittings are. Apparently, the pervious owner had a problem with the heater and just disconnected and plugged the lines. I found the diagram in Haynes 280ZX. It is on page 66, Fig 2.2 External components of the engine (right side). There are two tees, one that goes into the water inlet and off the top there is a short piece of hose that goes to? Then there is some type of fitting the mounts/screws into the block in the back and then goes up to the heater core. What is it? Does it feed water to the block? Then there is the other tee that comes off the water inlet and goes back, not sure what the circulation path is. If anyone came please help me I would appreciate your help.
Thanks,
Big E
TylerSkidmore
Oct 9, 2011 08:35 PM
colin_barnes
Mar 15, 2006 11:48 AM
WhtFairLadyZ
Jan 3, 2005 09:13 AM
gamemannn
Dec 29, 2004 06:26 AM
dwende170
Jun 13, 2003 07:37 AM
