Guage swing & Engine shutdown
Old Jul 16, 2011 | 12:43 PM
alshotrodgarage's Avatar
Hope to find some help from you Z guys! I build street rods and am not that familiar with the Japanese/Bosch injection. I'm trying to sort out a friends 1977 280 . problem, Engine will start and run fine at all rpms untill it gets up to operating temp. then it suddenly dies and will not restart untill it cools down.Fuel pressure is a constant 34 to 38 psi. Injectors are firing as are the plugs. other issue is when ign. is on or car is running the volt meter does'nt work (alt. is putting out 13.8 volts). Also fuel,temp,oil pressure guages swing either when running or with ign. on. Any help would be appreaciated. thanks Al.
Old Jul 16, 2011 | 02:59 PM
noboosts130's Avatar
Lurker
The dying problem sounds like a bad ignition control module on the side of the dizzy.
Old Jul 17, 2011 | 09:39 PM
theramz's Avatar
I have a present for you...
Does it slowly die or is it like you turn off the key? Do you have spark and fuel pressure after it dies?
Old Jul 18, 2011 | 07:43 AM
It just suddenly dies! Checked fuel pressure & spark as well as injector voltage after each episode, every thing is there! Damndest thing I have ever seen! Logic says it should start. I was told that unlike OBD 1&2 the Z computer cannot be scanned. I'm going to check for voltage swing at the guages and try to figure why. Do all guages run thru the computer? Thanks Al.
Old Jul 18, 2011 | 09:46 AM
theramz's Avatar
Some event is shutting down the ecu. Verify this with a noid light. The ecu is turned on by the ignition control module via the ign switch. The dying could be caused by the regulator shutting down after it cycles open. The gauge swing indicates a complete loss of electrical power to the engine harness.
The afm controls the fuel pump so check the tps per the factory service manual. It will shut down the fuel pump if it senses a stopage in air flow.
Please post your findings because this is just one of many problems the newb encounters.
Z_lover
Aug 23, 2010 05:52 AM
ZXT83
Mar 9, 2010 07:26 PM
The_MuffinMan25
Aug 21, 2008 06:27 AM
dragonsfear
Dec 17, 2002 04:17 PM
Slick_84_AE
Aug 7, 2001 03:24 PM
