Converting the steering rack to pwr
Old Oct 27, 2003 | 05:41 PM
GodZilla's Avatar
Banned
Going to use this rack for converting my 240Z to power steering.
Old Oct 27, 2003 | 08:08 PM
auxilary's Avatar
the Dude
Kyle, that's a very wide rack. Are you chopping the tie rods, or having custom ones built? What's it from? (I'm almost tempted to say Mustang, but it's the wrong shape)
Apparently a Miata rack is almost identical length and mount points to the Z unit, and hte FC rx7 is pretty close
Old Oct 27, 2003 | 08:26 PM
theramz's Avatar
I have a present for you...
cool idea! You should be able to use short arms with it too. Looks more like a Nissan Max. Are you going to have to change the angle of the steering coupler?
Old Oct 28, 2003 | 10:06 AM
GodZilla's Avatar
Banned
Its from my STI
Old Oct 28, 2003 | 01:53 PM
...for the cool factor. Obviously not for less weight or engine drag because that is what you don't get with power steering. Its nice just for cruising.
Old Oct 28, 2003 | 04:49 PM
GodZilla's Avatar
Banned
since I'm going to be running way wider tires on the front I dont think my arms will be strong enough to turn the wheels without it LOL
Old Oct 29, 2003 | 11:10 AM
GodZilla's Avatar
Banned
Well the good news and bad news..
The rack will work but you would need to modify a few things.
1) if your using the stock motor mounts from the front crossmember you would need to probably trim a section out of the mount for it to fit.
2) You would need to either knotch or indent the crossmember for one of the powersteering lines to clear the crossmember.
3) Make new mounting brackets for the rack
4) Bend new lines for the set up
5) Get an adaptor joint for the steering colomn to the rack.
6) Get a power steering pump..
7) Adapt the Tie Rod ends from Stock setup to the new rack
I think thats about it..
Old Oct 29, 2003 | 02:13 PM
GodZilla's Avatar
Banned
Yeah but those mods are simple compared to everything else I'm doing LOL
ITSZX
Mar 28, 2014 07:19 AM
hoov100
Jul 18, 2007 01:00 AM
jfairladyz
Mar 17, 2006 07:32 AM
graverhead
Dec 14, 2005 12:39 AM
goodtaste4all
Jan 27, 2002 05:13 PM
