Cold Run problems, still stumped..
Guest
Posts: n/a
82..280zxt
Yea, ive been trying to diagnose what is causing my car to run(not run rather) when the car is cold or in the first ten minutes of running. I have noticed that it often does not matter if it is warm, but it must have been running for over 10 minutes. After the 10-15 minute low period, the car runs great however. This problem has been occuring for almost 3 months.
Cylinder head temp sensor: pulled it off while running, and the car stalled.
Plugs: installed ngk plugs a month ago "non resistor".
Wires : Borg Wagner installed a month ago with plugs.
I checked most connectors for corrosion and used dielectric grease.
Any ideas for a solution???
Hopefully ill get this fixed within the next year heh
thanks again guys
Also, can you replace rear wheel bearings with basic tools or do you need them professionally done?
-Ryan
Rhode Island
thanks again guys
-Ryan
Rhode Island
johniii
Jan 11, 2014 12:43 PM
