Changed Batt now turn over no start??
Old Nov 10, 2013 | 03:48 PM
ZandVette's Avatar
Help my 75 had a 5 yr old batt, would not hold charge changed for new now car turns over but no start. Pump is running, did not have running problem before batt change, HELP
Old Nov 10, 2013 | 08:39 PM
Welcome to ZDriver!
Check for spark.
Check for fuel pressure.
Check fusible links.
Old Nov 10, 2013 | 09:25 PM
ZandVette's Avatar
Welcome to ZDriver!
Check for spark.
Tks: Checked fuel pump, will check spark tomorrow, fuse links were ck moved them back and forth, funny changed batt and something else happens.
Old Nov 11, 2013 | 05:49 AM
theramz's Avatar
I have a present for you...
You may have forgotten the 2 wires from the battery to the ecu. Also if you reversed them it won't start.
Old Nov 11, 2013 | 06:09 AM
Rooster's Avatar
A new, good battery can cause dodgy fuses and links to go (old batt couldn't push enough amps for that to happen)
Old Nov 11, 2013 | 10:53 AM
ZandVette's Avatar
Switched links no change ,where are fuses are you talking about? Ck spark to distributor 12 volt, but no fire to plug wires. Can rotor or points go bad at one time ?Maybe bad electronics on switch? CK gas pressure up.HELP Will look for ecm wires. TKS
Old Nov 12, 2013 | 03:46 PM
theramz's Avatar
You don't have points. Time to download the FSM and go step by step through it.
MO3IUSONE
51
Dec 19, 2016 03:22 PM
ZandVette
Apr 13, 2014 07:29 PM
smartman30000
Jun 20, 2010 07:52 PM
WichitaZRide
Aug 26, 2005 06:31 PM
sk8ur_9
Oct 31, 2004 09:10 PM
