Brake lights out
Old Oct 5, 2007 | 09:55 PM
Texizgreat's Avatar
Brake lights out
Just noticed the other night that my Brake lights are not working when pressing the brake. I just bought the (1978 280Z) Z at the begining of July and not sure now if they ever worked. Checked the Bulbs and all seem to be in good shape. Same with the fuses.
Other maybe related problem???
1. when I turn on the Right turn signal It does not flash. The light will come on and stay on. Left turn signal works just fine.
2. When I turn on Hazard lights they dont work either. infact when I flip the switch the Volt gage kinda freaks out.
Please any suggestions would be welcome my inspection is due THIS MONTH.......
Old Oct 6, 2007 | 09:33 AM
Brake switch... common prob. See page 136 of 240z-280z Haynes manual.
#1... check front and back turn bulbs
#2... check relay.
Old Oct 8, 2007 | 03:53 PM
Texizgreat's Avatar
Replaced Brake light switch and brake bulbs... Got one to come on however it is not the BRAKE light it is the lights on switch.
I did find an after market bulb socket installed kinda shotty (passenger side). Seeing if I can replace that tonight.
so still no "Brake lights"
Are the lights in the Z in series? the reason I ask is when one goes out it seems to affect others.
Old Oct 8, 2007 | 04:44 PM
is the little rubber plug on the brake pedal still?
Old Oct 8, 2007 | 06:50 PM
Texizgreat's Avatar
Well sorta ... lets just say whats there works... lol
Replaced flasher unit (hazards still dont work)
replaced Bulb socket on passenger side. Now with that, when I turn on the head lights both filiments (sp) are on on the passenger side are on. Still no brake lights when i press the pedal.
Old Oct 9, 2007 | 10:25 AM
Texizgreat's Avatar
Ok ok .... Got flashers to work by cleaning the fusible link terminals. but only while the car is on.
Still no luck with the brake lights.
Old Oct 9, 2007 | 10:49 AM
Texizgreat's Avatar
volt ohm meter reads zero resistance when wires are unplugged and open and full resistance when no brake applied. so i tested the resistance with just the two wires and nothing is passing.
I think the prob is wires under the dash some where....... no fun
elenorzx
Apr 26, 2013 03:12 PM
280fun
Jun 11, 2012 11:01 PM
Geoff
Mar 22, 2011 07:39 PM
300zxman
Feb 23, 2008 12:59 PM
Kidcorona
Oct 13, 2006 10:10 PM
