Battery Lead Connection
Guest
Posts: n/a
Ok, I took it apart last fall and did not notice exactly how the leads from the battery connect to the starter.
I trust the + lead goes to the + side of the solenoid - Correct??
The ground goes to a tranny bolt or suitable grounding location correct??
Also there is a lead from the wiring harness that via a nylon connector also needs to go to the soleniod. Positive or negative connection??
I would appreciate any assist you may have on this one.
