240z motor
240z motor
hey guys, whats a 240z motor and 4 speed worth to sell. i will be aquiring one soon, and dont know if i should keep or part out. its got dual su carbs, thats all i know aboot it. any ideas on prices for stuff. the rods are good for stroker motors, the su's are good, what aboot the rest?
ummm.... as a whole the engine alone is like 200 i think if in good condition. tranny... maybe aboot a huundo. if you can sell it as a whole rods are good for the strokers yup, and find out what type SU carbs... such as if tehy are round top or flat top and how many screws hold on the tops of them the slide and oil housing looks like a bell.. technical term is slipping my mind. lol. might be able to sell oil pressure send thermo housing and thermostat basic stuff... distributor... idk not much to actually part from the motor other than carbs manifolds and rods....
o.k got the 240 motor, its rough, but its got the dual su carbs, how do i tell what kind they are, and do ppl need them, or should i make dual tb's with them. the head is a e88, i like that, its a keeper. now i just need a diesel maxima crank, cause i got the rods!!
Argueably the '73 240 was the best. It had th 4 screw, bell top su carbs, the E88 head and was the only one that had the 9mm rods. I think the 72 had 4 screw carbs also. The earlier E31 head was the best for racing. The 260 had the flat top carbs which are worthless. It had the 280 crank which will fit all L6 engines. It had a smog version of the E88 head with smaller quench area that makes the head run hotter(nfg). It does have the larger intake manifold.
