240 Z questions
Old Nov 27, 2002 | 03:36 PM
auxilary's Avatar
the Dude
Re: 240 Z questions
Well, reliable is a variable term - you're talking about a 30 year old car, and there's no such thing as constant reliability with a 30 year old car unless things have been replaced/rebuilt. It doesn't have power steering, none of the Zs until mark 2 280zxs do. 70 and 71 models had problems with rear differential positioned slightly forward and that caused the halfshafts to be bent at an angle back, which caused common u-joint breaking. This was fixed in 72 and up by changing the rear crossmember and angling it back.
a carb'd engine is just as reliable as a fuel injected motor if you're talking about the block itself. Carbs require tuning, and behave differently under hot/cold conditions, but can make more power than the FI counterpart. 70-72 came with round top SU carbs, and 70 and early 71s came with the e31 head which is more desirable for better performance/compression. 72 and 73 came with e88 heads to be more compliant with new emission laws. 73 came with crappy carbs that everyone dislikes and replaces. And yes, it's easy to work on.
Does it handle well? if the suspension is in good shape, for its time it handled very well. if the struts are blown, that's a whole different story. My suspension is nowhere near stock, so I really can't relate since my car handles better than most sporty cars out there. The strut tower brace helps, but that's not something I'd bother with for a mod in my case. It'd always get in the way of motor access. If I was to use one, I'd make one that doesn't have bolts in its design, so it would actually be useful. To answer your question, do strut braces improve handling - that varies from car to car. If the chassis flexes a lot, it will help a bit. But hte problem is that most braces are 2 point braces - so there's no 3rd reference point
'73 240z
'99 neon R/T
Old Nov 28, 2002 | 12:53 PM
auxilary's Avatar
the Dude
Re: 240 Z questions
no, it's not hard to drive unless the steering rack is shot. the Z is pretty friendly to drive provided that everything is maintained well (ie. everything needed to be greased is greased, and bushings/bearings aren't shot)
a TRUE fairlady Z 432 was a 240z sold only in japan, very limited production numbers (420), had a crossflow hemi head, 4.4:1 limited slip rear differential, and an s20 block instead of l24 (meaning it was 2 liter 6 cylinder vs. 2.4 liter 6 cylinder) making 160hp. transmission was a racing transmission with close gears.
late 71 240z would be ideal if you want a slightly better motor, 72 would be ideal, imo.
'73 240z
'99 neon R/T
Old Nov 28, 2002 | 06:43 PM
Skully's Avatar
Re: 240 Z questions
manual sometimes comes in more handy when yer car stalls and yer power steering pump and brakes dont pump...well....good luck...
and alan....wer all buff, with big ******** over the internet
Old Nov 28, 2002 | 06:57 PM
auxilary's Avatar
the Dude
Re: 240 Z questions
The 432 -R is the one where you could specify gear ratios from factory, i think.
'73 240z
'99 neon R/T
Bdan57
Feb 5, 2010 12:42 PM
81-280zxnt
Nov 23, 2009 01:24 PM
81-280zxnt
Oct 20, 2009 12:02 PM
SandW
Oct 11, 2006 08:08 AM
pearly whites
Aug 18, 2004 06:20 PM
