1980 280ZX Won't Start
Old Nov 25, 2002 | 08:27 AM
Re: 1980 280ZX Won't Start
Having the crankshaft pully come off is sort of like having a timing chain break. (if that ever happens) Your pistons continue to go up and down while the valves will come to a slow stop. If that is actually what happened, then all of your valves are bent, and all of your cylinders have hard indentations where they hit the valves. I bought a parts truck with an L20b in it that had this happen to it. If that is the case then the techs at Nissan were right. You need a complete rebuild. Most likely you don 't need a whole new engine, but 6 brand new pistons, new valves, valve guides, cam and followers would be a good start.
Your valves are probably bent to one side a little and not sealing when the cam lets tension off. Therefore your cylinder pressure would be extremely low or maybe none at all. that is why it won't start. Do a compression test to verify this.
frawleyfly
Sep 29, 2013 08:24 PM
280zman
Jan 24, 2013 01:31 PM
moorebl
Apr 14, 2011 03:28 PM
EatmyDust
May 12, 2005 08:03 PM
zxrick
Sep 21, 2004 07:25 PM
