will i ever pass emisions
Old Dec 8, 2006 | 04:11 PM
280z4life's Avatar
i have a 77 280z i bought about a year ago and it's time for me to renew my tags. so i was looking at my engine and the previous owner put a header on blocked off the egr took off the cat and there is no O2 sensor. i put a cat on that i got from my friend and took it though the deq test it failed. what do you think i should do to get it to pass?
I'm currently collecting parts for a turbo swap and i was going to run megasquirt if i put ms on now could i get to pass?
Old Dec 8, 2006 | 04:59 PM
skittle's Avatar
Taste My Rainbow
Where Do You Live? And A Ms Setup Can Help You Pass It Depends On How You Have It Setup.
Old Dec 8, 2006 | 05:17 PM
jfairladyz's Avatar
First of all it would help if we knew in how you failed. If it was you NOx, then it is no doubt due to the fact that the EGR is blocked off. But we need more info before we can give you any good advice.
Old Dec 8, 2006 | 07:26 PM
my car passed flying colors with the egr dissconnected. all you need to offset that is a bottle of methyl hydrate, plus fill up your rear tires, it helps reduce drag on the dyno, thus creating less rolling resistance, also you can unplug #5 injector if there is no visual inspection, the #5 acts like a air pump, and runs on only 5, then it helps to lower the emmisions. it may sound odd, but all this stuff works, i can get and l28 n/a to pass with these simple tips, also raise your idle to 1000 rpm. try it, and post more info if it still doesnt pass
Old Dec 8, 2006 | 08:34 PM
skittle's Avatar
Taste My Rainbow
Where I LIVE They Don't Do It On A Dyyno The Stick It In The Pipe.
Old Dec 8, 2006 | 09:06 PM
in your faces.... move to IL we no longer emmision anything but OBDII boo yah.. that or register it with classic plates. they dont emmision those cars..
Old Dec 8, 2006 | 10:05 PM
jfairladyz's Avatar
south dakota doesn't have emissions testing at all
Another perk is there is plenty of E85 out here and it's only $1.65 a gallon for 100+ octane...guess what my engine swap is going to run off of
Old Dec 9, 2006 | 12:11 AM
what ever... i hope you havent taken out your engine and **** yet. i want some pictures for reference. ugh....
Old Dec 9, 2006 | 12:17 AM
skittle's Avatar
Taste My Rainbow
yeah if i move to nebraska no emissions thank god
Old Dec 9, 2006 | 03:22 AM
280z4life's Avatar
i live in portland OR there is no dyno and they don't test for NOX. i got a 4.0 on the CO i need a 2.5 and i got a 650 on the HC i need a 300
thanks
Old Dec 9, 2006 | 09:46 AM
Without a cat, it's REALLY hard to pass emissions. REALLY HARD. Did the previous owner say it passed like that last time? 650ppm HC is pretty high and without a cat you won't ever get it under 400.
So do this:
-Install a cat
-Make sure the timing is adjusted correctly (or even retarded slightly)
PS... When I took my Porsche to emissions, the HC was 21,000ppm. OOFA!!!
Old Dec 9, 2006 | 10:40 AM
21,000....... did the people there like **** there pants when that came up...
Old Dec 10, 2006 | 11:32 AM
RodMoyes's Avatar
Doesn't post much...
That year didn't have an o2 sensor anyway's... If it's running that rich, it's either your AFM, Water temp sensor, or possibly a bad fuel regulator (Most likely not though) or really bad fuel injectors...
Rod.
Old Dec 10, 2006 | 12:44 PM
skittle's Avatar
Taste My Rainbow
what if your car does not require a cat? can you use a dog instead?
Old Dec 10, 2006 | 12:51 PM
I think a mouse would be more appropriate... er no... a monkey!
Old Dec 10, 2006 | 01:11 PM
skittle's Avatar
Taste My Rainbow
i dunno about that I have 6 gerbils running in my engine already
Old Dec 10, 2006 | 02:47 PM
z-hag's Avatar
Queen of Yachts
bring it to cali--1977 this year no smog. no jk. 20 years.
Old Dec 10, 2006 | 03:02 PM
WTF?! California, the smog **** capital of the US, only goes back 20 years? Utah requires emissions for all cars 67 & newer... that rule hasn't changed in years.
Old Dec 10, 2006 | 03:34 PM
wreckedj30's Avatar
No Club Love
really, yeah its like a 20 yr. deadline...someday even my car won't need smog, but by then it'll probably be yours, then mine again...haha
Old Dec 10, 2006 | 03:38 PM
skittle's Avatar
Taste My Rainbow
In Vegas Its 68... How Can That Be? We Have Nothing But Casinos And Dirt.
Old Dec 10, 2006 | 04:01 PM
duowing's Avatar
NisTuner
Here in Ohio, after 25 years you don't need emissions, because then it's a classic car. Also I hear in the next year or so at least out this way we're supposed to be doing away with emissions tests.
Old Dec 10, 2006 | 05:39 PM
up here in b.c. we have the same emmisions program as cali. it sucks
jmmorriso
Apr 24, 2010 01:27 PM
thxone
Sep 27, 2007 07:36 PM
Turbo86
May 17, 2007 06:00 AM
gabrielzzz
Jun 2, 2006 04:12 PM
jhayes169
Aug 30, 2004 02:46 PM
