Where/what is this leak coming from???
Old Nov 5, 2010 | 01:19 PM
Datsun_Husky's Avatar
Ok, so I've finally got the engine to turn over, and I realize I have a ignition timing issue since I have to retard the dist. way back to the point of taking the locking bolt out.
Anyway... I've just noticed my engine is leaking coolant D: just when I thought I did something right for once, something else f-cks up!
It doesn't appear to be oil, thankfully but I'm questionable because some of the droplets are black. I may end up having to rebuild the engine yet again
I suspect the water pump. The coolant seems to just pour out just under my main pully it seems. I'll have a video soon enough to further show what's going on exactly, unless someone can help me without video proof.
Thanks in advance!
PS: I have no clue if this has been posted in the correct area so if not then inform me before I **** off an admin :P
Old Nov 5, 2010 | 06:45 PM
BlueKitsune's Avatar
Intrawebz Wizard
If its leaking from the weephole on the water pump the "black stuff" could be the remains of the seal of the water pump mixed in with the coolant.
Also if you didn't clean out the head and blocks cooling passages well enough it would simply just be crud left over from the rebuild as well
Old Nov 6, 2010 | 12:41 PM
Ok, yeah; just confirmed it is the pump, after letting the engine warm up abit (and a few revving sexy sound bytes for the ears ) The pump started to make that typical squeaking noise. I'm guessing the seal is totally dead now but I'll get to pricing new pumps. however if I keep seeing this black sh*t flying around then I may go for broke @_@
Old Nov 6, 2010 | 05:13 PM
Intrawebz Wizard
Have you checked your coolant to see if its not black as well??? and your oil too? I still think its just whatever is left in the cooling system of whats left of that water pump seal
Old Nov 8, 2010 | 09:03 PM
Speed's Avatar
Yep!
Sounds like the water pump. Is you main pulley - the one that the fan mounts to (orginal) unless you have removed the mechanical fan and are now running an electric fan.
Speed
Old Nov 8, 2010 | 09:07 PM
Originally Posted by Speed
Yep!
Speed
I've still got the manual pulley one and keeping it I just don't trust iron with a fan that isn't on at all times. If it were aluminium then that would be a different scenario :P
d33zdrama
14
Mar 3, 2012 05:15 PM
wake2wake21
Jul 24, 2008 09:49 AM
n00blar
Jun 9, 2006 11:29 PM
HDPD350Z
Jan 21, 2006 11:55 PM
Dorifto
Oct 14, 2005 02:48 PM
