What EGR plug do I need for 1978 280Z?
Old Mar 24, 2011 | 04:28 PM
dankfrye@charte's Avatar
My EGR tube on my 1978 280Z has a bad exhaust leak where it comes out of the manifold. The past owner tried to repair it with metal tap but that obviously didn't work too good. I want to take it out and plug the hole in the manifold. I've done a lot of research on the correct plug size but can't seem to get a common
answer. I've heard 22mm, 3/4 NPT Brass and several others. Does anyone know the correct plug that I need?
Thanks'
Dan
Old Mar 24, 2011 | 06:08 PM
evandubya's Avatar
Primer Grey FTW!
I don't know if you have a welder, but I just welded the hole up in the fitting thats in the manifold. It can still come out I just turned it in to a plug.
Old Mar 24, 2011 | 07:22 PM
Thanks for the suggestion! My body man has a welder and we might do that.
Old Mar 24, 2011 | 08:53 PM
Welding is an option... you could also just take off the pipe and take it to your local parts store / hardware store and find a match.
Old Mar 25, 2011 | 12:31 PM
Will do! Thanks!
wallace millner
Jan 12, 2013 03:01 PM
wallace millner
Jul 18, 2012 05:39 AM
Texizgreat
Jan 2, 2008 06:41 AM
brad101010
Mar 10, 2006 09:09 AM
Jammer
Aug 3, 2003 05:14 PM
