Tach won't work
Old May 18, 2004 | 06:46 AM
ayperric's Avatar
Unhappy Tach won't work
I have a 73 240Z with a 75 280z motor. I installed a new coil and now the tach won't work (it did prior to the new coil). Does anyone know what I could have mis-wired?
Old Jun 6, 2004 | 09:38 PM
theramz's Avatar
I have a present for you...
Check to see if you reversed the wires on the positive side with the negative side, the car will still run but the tach gets its' read from the negative side.
Old Jun 7, 2004 | 12:06 PM
ksampara's Avatar
I am in the same boat. I have a 71 240 which I updated to a electronic ignition and now can't get the tach to work? If I were to rewire it; it is from the negative coil post to the tach? Trouble is my tach didn't work prior to the new ignition? How many wires go to the tach (It is the one held in place by wing nuts?). Thanks, Kurt.
Old Jun 7, 2004 | 07:04 PM
theramz's Avatar
pain in the tach
Not sure about that but I found good info at http://www.geocities.com/motorcity/s...538/howto.html . Also i recall seeing an article on this at zhome.com.
Old Jun 8, 2004 | 04:13 AM
ksampara's Avatar
Thank you Tom. The rack went in nicely, just waiting to get it aligned. Slowly but surely. One question while I have you. My car has sat for seven years, and when I start it it will run rich and smoke (Black/rich) each time I rev it up? Once run hard and then reved it will not smoke much at all? The car has 3x40DCOE's and a cam (Lumpy idle). Is it not ment to idle long? It should be on the road permanently soon and hopefully work its self clean. Thanks, Kurt.
Old Jun 8, 2004 | 08:54 PM
theramz's Avatar
That set up is meant for racing only. Many people successfully retune them for daily driving. There are two books on Webers available from MSA for $16.95 ea., a wise investment since the Webers are not that complicated when you know what screw to turn which way. With that much carburation the jetting is more critical especially if their has been an altitude change from where they were tuned last. I would rebuild them since they have been sitting so long, right after I bought the books.
Old Jun 9, 2004 | 11:48 AM
ksampara's Avatar
Thank you. They are so intimidating though, maybe after the book, and when there is snow on the ground I will take a crack at them. I am just happy it runs at this point. So many bigger fish to fry. I have been trying to send pictures for a while now; hope these come through. Kurt.
Old Jun 9, 2004 | 08:30 PM
theramz's Avatar
oh yeah! Your off to a great start. Looks like you got a good solid body and fenders.
Old Jun 11, 2004 | 04:42 AM
ksampara's Avatar
I had a few small rust holes the the floor which I fiberglassed, and there looks to be some bondo or something (not much) in front of the rear wheels. The paint is bad too. Interior needs a center counsel and seat covers, the rest is really not bad. The expensive performance items are already there; Older; but at least there. Keep you informed, Kurt.
batmobile300zx
Mar 27, 2011 01:58 PM
Comrade_Charlie
Mar 17, 2007 02:46 PM
FubarI33t
Mar 7, 2007 09:08 AM
serg92
Nov 25, 2002 11:05 PM
wiebejosh
Apr 14, 2001 06:10 AM
