starting problems...
Old 07-04-2006, 05:54 PM
FairladyZS30's Avatar
okay i started my 280z using starter fluid and it starts but until we push the gas pedal it dies......and if we start it it again and spray more starter fluid and push the gas...it doesnt die unless we stop spraying starter fuid and pusing the pedal..any help?
FairladyZS30 is offline
Old 07-04-2006, 10:34 PM
No or not enough fuel... check fuel pressure, pump, filter, injectors, ecu, wiring.
NismoPick is offline
Old 07-04-2006, 11:11 PM
wiring ecu is fine pump is ias also fine injectors seem to be doing its job....fuel filter...i gotta look into that and theres also this one hole..that iono where it leads to its after the AMF and theres suppose to be a hose leading to somewhere..but iono where too
OsidonZ31
03-10-2014 12:47 PM
300zgearhead
07-21-2010 04:04 PM
TeamRonin
02-18-2010 01:22 AM
Stubby
05-07-2005 11:18 AM
Blockmaster
08-02-2002 01:55 PM
Quick Reply: starting problems...
