slight knocking noise
Old Dec 14, 2004 | 05:25 PM
280Z4ME's Avatar
Pull the valve cover and have a look see. That is about all I can tell you. The gasket usually doesnt break on the valave cover when you remove it.
Good Luck
Old Dec 14, 2004 | 07:34 PM
EZDUZIT's Avatar
East Coast Style
I will have to go with your dad on this one. My brother has a 74 260Z and he called me up about 2 months ago and said he is going to have to rebuild his engine. I said why? It runs great , he said its knocking like a rod or valvetrain. In said bring it by after work. So he did and I listened to the motor run. Then I pulled out the exspensive engine diagnostics (a long screwdriver and held it to my ear) I placed it on the water pump and that was it . The bearing was going out and making a rattleing noise. So I would say check the simple stuff first! JOSH
Old Jan 28, 2005 | 11:50 PM
Fast240Z's Avatar
yeah, check the water pump, and it could also be that you might not get enough oil up into your rockers for those cylinders.
Roshane Udugama
Mar 28, 2014 12:31 PM
Annee Heath
Aug 29, 2012 05:21 PM
hchase17
May 2, 2009 11:03 PM
Zed59
Jul 25, 2008 11:12 AM
forcedfedz32
Sep 30, 2005 07:17 PM
