No Electrical!!! 240Z !!! Help!!!
Old Sep 9, 2012 | 09:21 PM
s30dan's Avatar
Exclamation No Electrical!!! 240Z !!! Help!!!
Hey, thanks for reading guys, If you can help I gladly appreciate it. My problem is I Bought a 1972 240z from the origional owner. He wanted to get rid of it asap. I got it for 500.00. It was pulled like 1/3 of the way for restoration, so I did a total restoration on it. Pulled everything except the main wire harness. I reconnected all the wires: New battery----->New starter----->new Alternator----> New Ignition coil and etc... New Fuses too and connected the dash board carefully back together. I turn the key to the ON position and nothing except the hazard lights are working. So I rechecked all the wiring like 3 times. and still nothing. Please help. I am at a dead end. I spent alot into this restoration
Old Sep 10, 2012 | 08:43 AM
PredatorZ's Avatar
FSM Link
I'm guessing you don't have a Service Manual, so here is a link to one you can download for free, follow the troubleshooting steps to work through what is and isn't working properly. Redo your grounds, make sure your battery has a ground to the frame. just not the starter. Check your fusible links with a multimeter to make sure you have good connections. Hopefully one of the electrical Guru's will be on later and give you additional places to look. The turn signal multi-switch can go bad and kill an older Z and cause all kinds of issues, make sure your ignition switch is working properly also.
http://www.xenons30.com/reference.html
Old Sep 10, 2012 | 08:50 AM
PredatorZ's Avatar
Welcome to the Club
Grats on your new Z and welcome to the forums, and good luck on finding and fixing the problem your having. This is a great resource for Z owners and lots of knowledgeable guys always willing to bend your ear. The search works pretty good , and you will find lots of posts about electrical issues, and most likely lead you to a fix.
Old Sep 10, 2012 | 10:42 AM
Twiggs280zx's Avatar
Welcome
How is the Z scene in AK? I was raised in Palmer but havent been there in 7 years.
Pics?
Old Sep 16, 2012 | 09:55 AM
s30dan's Avatar
Thanks!
I was working on it over the weekend. and finally got the electrical to work. For some reason. I used a multimeter to check out all of the electrical. All of the grounds are GOOD. The thing is It is temporary, I Hot wired a electrical from the starter to the alternator then all of the electrical works.. My uncle came and took a looked at it. He says maybe some of the relays are fried? When I take off the WIRE I hot wired. None of the electrical works... I Download a copy of the manual for my year. Thanks. Will look to it for future reference.
Are the relays hard to replace?
Would I need to touch the electricals inside the dash board?
Old Sep 16, 2012 | 10:30 AM
s30dan's Avatar
Greetings!
Pics?
Hello! Fellow Alaskan! Once one always one! Its Great When the sun is out! But Its been raining like last summer. I was hoping to get my 240z up and running so i can take some nice scenery photos buts its not gonna happen anytime soon. Summer almost over.
Attached Thumbnails No Electrical!!! 240Z !!! Help!!!-imag0032.jpg   No Electrical!!! 240Z !!! Help!!!-img_0290.jpg   No Electrical!!! 240Z !!! Help!!!-img_0274.jpg
stiletto660
Oct 9, 2013 07:04 AM
DZcrew
Jul 15, 2011 11:26 AM
GaZ
Nov 6, 2002 10:48 PM
Kathryn
Oct 13, 2002 02:40 PM
leemarshall50
Jun 12, 2002 06:28 PM
