idle keeps wanting to go higher
Old Mar 9, 2004 | 10:23 AM
My idea is sticky throttle linkage. You've got quite a linkage setup with the dual SU's there. Disasemble it and clean it with WD-40. Dry it and apply small amounts of grease inside each of the ball in socket joints. Then, maybe add a slightly stronger throttle return spring or put a second one on. I've seen many multi-carb setups with two throttle return springs spaced out on various points of the linkage. This will also give the gas pedal a slightly more firm feel.
Old Apr 8, 2004 | 01:49 PM
Thumbs up
Originally Posted by OlderThanMe
wow bleach... we think the same thing at the same time in different parts of this huge country... amazing
I think you deserve to be the 240Z Forum Moderator!
Fourplants
Feb 19, 2012 07:41 PM
jofwolves
Jul 28, 2011 03:28 PM
patrickclee
Jul 22, 2006 05:16 PM
280ZXTLVR
Mar 16, 2002 04:53 AM
Zpeed
Mar 15, 2002 07:02 AM
