Misfire at higher rpm when warm
Hello everyone. I recently bought my z32tt and have been having a misfire when warm. At first we thought vacuum leak so we traced the system and fixed the leaks (3 of them) and no help. Then we thought boost leak, made a tester and tested everything seemed ok. Then I thought plugs. come to find out that the car has NGK iridiums. Did some research and found that the supposed correct plug is the NGK PFR6B-11B with a gap of 0.35 with my mild mods. My question is will the iridiums being a shorter plug cause a misfire at temperature? Should I go with the platinums? Never hurts to have another opinion. Thanks
What set of Iridiums are they? It's possible that they are too "hot" of a plug compared to the factory ones.
Also, dont assume plugs are the issue. It could be low compression, bad coolant temp sensor, etc.. If it's only missing when it's hot, then use that info to your advantage. What changes when the motor warms up? Then look those places for abnormalities.
Shorter plugs usually indicate a "colder" heat range. Having too cold of a plug isnt' necessarily bad. If you are, look at the tip of the plugs and see if they are sooty and/or black. This indicates an incomplete fuel burn. If they are white, then the plugs are too 'hot.'
Replaced fuel filter installed NGK pfr6b 11b, apexi afc neo and high flow cats to pass emissions test Dyno tuned 329.5 whp at 6450 rpm 345.6 ft lbs torque at 4800 rpm misfire is gone yay lol.
patrickclee
07-22-2006 05:16 PM
hjsouders
04-26-2004 06:04 PM
